A/V front jack input detection not working
Discussion in 'Tech Support' started by Simon bridgeford, 26 Apr 2011.
  1. Simon bridgeford
    Simon bridgeford i'm a pc
    25 Sep 2009
    when i plug headphone into my front jack my computer will play audio through my headphones and my speakers at the same time instead of switching.
    i have checked my mobo audio drivers and they are upto date on asus site
    my board is a asus p5n-73cm using via audio
    in the audio driver control panel it normally highlights detected inputs but none of my front jack inputs are detected but sound will travel to them
    it seems very odd to me
    hope someone can help me
    simon
  2. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    Have you tried turning the speakers off at the exact same moment you plug your headphones in?
  3. Simon bridgeford
    25 Sep 2009
    in order to fix the problem or just to stop audio coming out of the speakers
  4. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    If it's an Asus board it likely runs around on the Realtek chipset, rummage around the sound options in the Drivers, there's a few options in there to automatically-mute speakers, or enable Front Panel Audio detection (Seems to be turned off half the time. I 'unno why), check those first, if it still doesn't work: It's possibly a motherboard fault, try rolling back to slightly older drivers and see if that fixes it.
  5. Simon bridgeford
    25 Sep 2009
    thanks for the advice thing is it actually runs VIA audio probably cos it has a nvidia chipset
  6. .//TuNdRa
    12 Feb 2011
    Seriously? I thought the Nforce stuff still used the Realtek chips (At least my old 750a board did.) Still have a shuffle around the VIA audio control panel, it might be in there somewhere, but my experience only extends as far as Realtek or Xonar audio chips, sorry.
  7. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    What case are you using? If its a cheap or old case, then sometimes you have that problem. Its the wiring of the AC97 vs HD audio. You'll have to google it, but i've had this problem before.
