Case Mod - In Progress "Frozen Death" - CM690 II advanced edition, (Update) 1th November 2012
Discussion in 'Project Logs' started by ModsofNorway, 30 Oct 2012.
  1. ModsofNorway
    ModsofNorway What's a Dremel?
    7 Sep 2012
    Hello! :) After alot of researching and thinking, I finally descieded to make a new Case mod!! I wanted this one to be a clean and good looking case so i bought the Cooler Master 690 II advanced edition amog with the Corsair AX850 W power supply. This case will be painted black and blue and alot of details in the case will be in black and blue aswell!! I will give you a list of all the hardware soon, including the water cooling set I will add!!
    This is the first case mod I make for this forum, so take it easy on me ;)
    Stay tuned!
    Pictures.
    Part 1 - Introduction and Side Panel
    After waiting for almost two weeks, my case and cower suply finally arrived!! :)
    Review image of the case inside!
    Another image of the case!
    I started off by taking most of my case apart!
    Side panel is ready for the Jigsaw!! :)
    Work in progress!!
    The cutting with the jigsaw is done. On this image I'm checking how I want my sidepanel to be.
    I descieded to place the window outside of the case and use screws to attach it. I also tried to arrange some edges to have the screws through. But it didn't turn out the way a planed, so I took them away. The results came out pretty well.
    Here I'm about to drill holes for the screws.
    Side panel are ready for painting!
    The Sidepanel is fully coated. In the back you can also see that I have painted the front panel of the case! :)
    Here are the screws for the side panel ready for painting.
    Screws after painting (The color are dark metallic blue)
    Results of the side panel! I hope you like it.
    Part 2 - Painting the skeleton of the case and some other parts
    Some parts of the case are sanded down and ready for painting
    Dito
    Here are some results of the paint job.
    Ok! This is all I got for now. I hope you like it so far and if you have any question, don't be afraid to ask! :)
    I have ordered six new fans from Xigmatek (3x 120mm and 3x 140mm)
    - Water cooling are soon on the way
    - Most of the cables in the case will be sleeved with cables from MDPC-X
    - And if I can afford it, I will get 2x new GPU's of some kind! :)
    - I also wanna get an fan controller with atleast 6 channels!
    What I will do next now is to get the case back together! :p
    Stay tuned for more, and subscribe to get the latest news! :clap:
  2. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    Good start duude, will keep an eye on it! GL :)
  3. Jay88018
    Jay88018 What's a Dremel?
    5 Sep 2012
    Looking good, like the look of the front and top panels.....its like, i know something has been done, but its that subtle you have to look to tell what... i really like that. Keep up the good work, and keep posting :D
  4. ModsofNorway
    7 Sep 2012
    Thanks!!
    Thanks man! :) Glad to hear that!!
  5. ModsofNorway
    7 Sep 2012
    Yea, I was thinking the same! All i wanted to do was to do a nice touch to them! :)
  6. Ragequit
    Ragequit What's a Dremel?
    26 Apr 2012
    Liking it! Also, your nick is awesome :p
  7. KidMod-Southpaw
    28 Sep 2010
    Love the side panel! What a great start- keep it up! :thumb:
  8. ModsofNorway
    7 Sep 2012
    Hehe, thanks!! :)
  9. ModsofNorway
    7 Sep 2012
    Thanks! :) Looking forward to make another update! :)
  10. dreps
    dreps Minimodder
    3 Oct 2012
    looking great so far :rock:
  11. ModsofNorway
    7 Sep 2012
    Thanks!! :) There will be a new update tonight!
  12. ModsofNorway
    7 Sep 2012
    Update - 31th October 2012
    Hello!! I'm back with some new pictures and a update on what I have done on my case mod the last days!! I've mostly been working on getting my case back together, and I finally got my sleeves from MDPC-X and my fans from Xigmatek. I have been sleeving the cables on the new fans, and I also got done some sleeving on my power supply cables!!
    Check out the new pictures, and I hope you enjoy!! Leave a comment and let me know what you think, and don't forget to subscribe to get the latest updates :clap:
    Part 3 - Putting my case back together!
    The first painted part are back on the case!
    My case are getting back together pretty easily! I tought it would be alot more work on this part, but everything went pretty well!
    The other side of the case!
    The case are pretty much back together! And btw::: The fan control you see on that picture is NOT the one I wanna use!! That one is some old **** I found and painted really fast just to match it with the rest of the case!
    Back of my case! One of the side panels are not painted on that pictures as you can see! But is done now!!
    Part 4 - Sleeving and some unboxing!
    Got my Package from, Nils! :D MDPC-X
    :hehe:
    Quality from Germany!!! 10m - 3mm Blue sleeves, 10m - 3mm black sleeves and 5m - 5mm Blue S-ata sleeving!
    My Xigmatek fans has also arrived!! :D Awesome
    3x 140mm Xigmatek fans
    3x 120mm Xigmatek fans
    Xigmatek fans are ready for sleeving!!
    And this is the tools I use for sleeving!! This is pretty much a must!!
    Sleeving in progress!! Sry for the bad picture.. :sigh:
    Results of the fan cables! :)
    Today was my first time i sleeved Power supply cables, and I tried to get an system on it. I messed up alot, but the results turned out pretty well!!
    This is the results so far!! Still got alot of sleeving left!!
    S-ata cables sleeved! :)
    4-pin(?) cables sleeved.
    Also descieded to sleeve my stock fan. :p Hopefully I will get water cooling to my CPU and there will be no more use for this fan! :)
    Ok! This is all I got for now. I hope you liked it!! until next time I will get done some more sleeving on my Power supply cables, and hopefully get water cooling.
    Stay tuned for more Norwegian Case modding!! :)
