Networks FTTC modem/routers
Discussion in 'Hardware' started by bestseany, 24 Sep 2013.
  1. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    I've had Plusnet 80mbps fibre for a while now and whilst it's been great, the wireless on the supplied Thomson router is a bit poo.
    I'm looking for an all-in-one router with a VDSL2 modem and 5GHz wireless, but I'm struggling a bit. Draytek used to do some expensive ones but they've been discontinued and the new models are all 2.4GHz.
    I know I could just replace the router on its own, but I'd rather get rid of the Openreach modem at the same time if I'm spending the money.
    Has anyone found anything suitable?
  2. Krikkit
    21 Jan 2003
    Something like the Netgear DGND4000 looks quite good. Does ADSL2, but has a connector to allow fibre routing instead through a Gig-E port; add a modem and you're away.
  3. bestseany
    2 Jul 2009
    I'm trying to get rid of the Openreach modem, so trying to find a router with a VDSL2 modem built-in.
  4. Krikkit
    21 Jan 2003
    Well if you don't want a separate modem + router then the only one I can find is the Fritz!Box 7390.
    I would grab a modem, or use the Openreach one (as it is rather well rated from the details I can find) then open up to a world of awesome cable routers. In fact, looking for the latter scenario, the D-Link Archer C7 looks really good for super-fast wireless transfer speeds, reviewers have seen >1Gbps out of it easily.
  5. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    Draytek are one of the only companies that seem to make them and there all expensive
  6. bestseany
    2 Jul 2009
    Th Fritz!Box is a good find. Thanks. Although it is quite expensive.
    I'm surprised there isn't more modem/routers available for FTTC to be honest. I may have to go down the cable router path, but it would be nice to only have one box as my telephone table is a bit cramped at the moment :)
    Draytek used to make a suitable one but it's been discontinued, all the VDSL2 ones are now only 2.4GHz for some reason. You're right, they are all expensive.
  7. megadriveguy
    19 May 2010
    You mean the Draytek Vigor 2850Vn
    You will still maybe find it on ebay I would wait for a used one to pop up but they still go for around £150 used
    Ebay
    Your best off keeping the openreach modem and using something like the ASUS RT-N66U with it
  8. gazchaz
    gazchaz What's a Dremel?
    8 May 2009
  9. gazchaz
    8 May 2009
    Ignore that! Just noticed that also requires the openreach modem, DOH!
  10. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    You might as well keep the openreach modem it doesn't do much and doesn't really adversely affect anything.
    If you want a good router you could go with an rv series cisco, like an rv220w.
    If you really need a new modem go then the Cisco dpc range work.
    All depends on what your budget is really.
    Sent from my GT-I9505 using Tapatalk 4
