Modding Future shuttle plans!
Discussion in 'Modding' started by Jack, 16 Jan 2004.
  1. Jack
    Jack Minimodder
    22 Dec 2002
    Hi guys
    Im thinking up some new idea's for my shuttle and ive come up with this plan?
    Pls forgive the corner's i havent yet mastered doing that :D
    Any thought's, bits you guys dont like? Surgestions
    If you'd like to download the file its Here
    pl coments
  2. phaSe
    phaSe What's a Dremel?
    4 Jul 2002
    looks good to me!
    any more info? like what materials do the different colours mean?
    check out pc-max for some hardcore shuttle customisation!
    btw, the 'VOTING' thread and then 'Klick mich' takes you to some, but not all of the finished shots.
    RoB
  3. Jack
    Jack Minimodder
    22 Dec 2002
    Yeah ive been to pc-max ;) the mods are indeed very nice
    Right color guide is as followed
    Grey - brushed alui
    Black/sides/top - Window (might be black tinted unsure ATM)
    Blue - Blue plexi transparent
    black on front edges - New custom front spry'd black
    The skirt around the bottom will be custom made from probably wood with plexi lining it lighted blue via leds - the added base will also provide space for the shuttle PSU as it is to be relocated under the chassis.
    Also i might add another PSU as im thinking along the lines of overclocking this sucker - which means watercooling
    Im thinking along the lines of, Black ice micro Radiator - and a Res made th same shape as the PSU that will sit as if it was the PSU
    Not sure on a pump?? or waterblock ATM but all this will follow after the design change
  4. Nexxo
    23 Oct 2001
    Looks like a very nice design! :thumb: Good work.
    As for the watercooling setup: if you can live with small diameter tubing I'd go with Aqua-Computer and/or Innovatek stuff all the way, as it is space-efficient. Use the Swiftech MCP600 for a pump. Small, powerful, quiet, 12V. If you are tempted by larger diameter tubing (harder to accomodate in such a small space however, I would consider the Cathar's White Water block (the two-barb version; you have no space to mess with Y splitters).
  5. phaSe
    4 Jul 2002
    that looks really cool Jack,
    i like the sort of plexi 'shell' around the aluminium (i hope im interpreting the picture right!)
    RoB
    ps, hope you do a project log, this looks very interesting!
  6. Jack
    Jack Minimodder
    22 Dec 2002
    Cheers for the reply's guys
    Nexxo - Not really fused regarding tube size, but can you get a small rad with that type of barb??
    Anyone know where to get blue transparent plexi/acrylic from?
    Glow shop sells it but only in 250mm square i need just over 300mm square!
    i dont really fancy paying £60 for a 1m?? HELP
  7. phaSe
    4 Jul 2002
    check yellow pages? ring around a few places, otherwise, dunno, sorry dude.
    RoB
  8. Nexxo
    23 Oct 2001
    The Black Ice Micro has 9.5mm OD barbs, which according to Innovatek can still be used with their 8mm ID x 1mm wall thickness tubing. However I'm sure you can get adapters also.
    For plexi, also look at sign manufacturers.
  9. Jack
    Jack Minimodder
    22 Dec 2002
    Hi guys
    ive been adding more bits to the shuttle design, with the little time i do have on my hands! SORRY FOR THE LARGE IMAGE i wanted to show better detail
    ATM im struggling on the front design, Im not sure if i like the arch and dont know how/where to put the power/reset switch?
    any ideas.
  10. Langer
    Langer Jesse Lang
    24 Jan 2004
    Pretty sweet deal. Very nice work, good luck
    what prog is that image done in?
