Electronics G meter help.
Discussion in 'Modding' started by hcker2000, 4 Aug 2005.
  1. hcker2000
    hcker2000 What's a Dremel?
    21 Oct 2004
    Ok basicly I would like to make a horizontal gforce meter for in my car.
    What I Was thinking is some kind of gforce sensor + a pic + some leds.
    I don't know if this can be done cheaply or not. I hope so. Can any one point me to the gforce sensor that I could interface to a pic?
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    These here might not be as cheaply as you want them, but a plethora of people are familiar with them.
  3. Krikkit
    21 Jan 2003
    Wow, that's a damned cool chip. Modern electronics never cease to amaze me these days.
    Not cheap at $12.80 though :\
  4. iamnafets
    iamnafets What's a Dremel?
    24 Feb 2005
    If you ever get around to it, post the results here, and a schematic if you get the chance. I'd love to make one of these :). I always pull this turn at like 40mph and it throws coke cans across the car, I'd love to see the force.
  5. hcker2000
    21 Oct 2004
    12 bucks is fine sence I only need one for the project. The worst problem is it is so dang small :/
    Any one know what pic would be best for this project. Basicly I was thinking 5 leds on each side (for left and right forces).
    Some thing like this.
    OOOOOXOOOOO
    And lets say I make a left turn
    OOOOOXXXXOO
    X = lit leds
    O = unlit leds.
    EDIT: Kind of like this but alot simpler and cheaper. I will definitly post the pic code once I can figure out how to get this done.
  6. hcker2000
    21 Oct 2004
    So could any one who has worked with these sensors give me some help as to interfacing them to a pic. I have never done any thing with the built in A/D on a pic16f88 before now so.
  7. Lynx
    Lynx What's a Dremel?
    24 Nov 2001
    I havent used those chips but some from analog devices. Those are simply interfaced by running the output into an ADC.
  8. shotgunefx
    shotgunefx What's a Dremel?
    4 Feb 2004
    I have a Memsic 2125 Dual-Axis Accelerometer for my car. Haven't gotten around to installing it yet as I'm not sure if I want to use it to measure force or as a tilt sensor for the steering wheel.
    If you go to parallax's site, they have basic stamp code for working with them. You should be able to translate that fairly easily.
  9. hcker2000
    21 Oct 2004
    Thanks so is the chip from sparkfun about my best option?
  10. davew
    davew What's a Dremel?
    13 Mar 2004
    Have you seen the pre-soldered (I think?) 'breakout board' they do? A lot extra to pay though :sigh:
  11. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    Try searching the Sparkfun.com forums on use of that chip. You are probably not the only one to be using it for this purpose, and more than likely someone else who has bought it from Sparkfun would post results on their forum. :thumb:
  12. Xiachunyi
    3 Nov 2003
    Actually, I was pointing to the other accelerometers that can interface directly to digital input lines of a microprocessor.
  13. hcker2000
    21 Oct 2004
    Oh well the link to sparkfun was only for there main page.
  14. One~Zero
    9 Sep 2004
  15. Xiachunyi
    3 Nov 2003
    Yeah, I forgot to mention their, I would assume,session browsing:
    "http://www.sparkfun.com/shop/index.php?shop=1&cart=350724&cat=71&" hmmm...
    Oh well, if you did not deviate from the main page, the right navigation menu holding the section, "sensors", have a variety of accelerometers that are easier to interface but have a multiple price add-on.
  16. hcker2000
    21 Oct 2004
    Yea most of the other sensors are expensive. Is using an ADC on a pic very hard? I have no experiance with that part of a pic as of yet.
  17. SoulDaddy
    SoulDaddy What's a Dremel?
    5 Jul 2005
    I actually make these every now and then and sell them. I use the adxl311 or adxl320. I then use 10 bit ADC on a PIC16F876A and display it on a 16x2 char backlit LCD. the ADC is piss easy on the PIC as long as you set it up right. I run the LCD from the PIC in 8-bit mode. It works very nice and you can add some bars for graphics. tune me if you need help.
  18. hcker2000
    21 Oct 2004
    Yea I definitly need a bit of help with it. I dont mind the cost of the sensors so long as I know I can get help geting it to work. I'm heading to bed but if you could pm me some of your code to look over that would be a great big help. Then I can start asking specific questions and such.
    EDIT: I'm sure two g's is more than enough for most any car aside from decked out race cars. Also if you can link to a source of the sensors you use that would also be great.
  19. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    If using an analog accelerometer is a problem there are also various digital accelerometers. I'm using a 3-axis SPI accelerometer in a current project (though I should mention it's in a DFN package - which is quite similar to the QFN package of those Freescale chips.
  20. hcker2000
    21 Oct 2004
    I dont know if it is a big problem or not considering alot of pics have the ADC built in. Usualy only one though so that dose limit my axis down to just one. Heck if I realy knew what I was doing I bet you wouldent even need a pic.
