game instaltion trouble
Discussion in 'Hardware' started by subterrian, 3 Oct 2008.
  1. subterrian
    subterrian This is the end
    28 Aug 2008
    after installing "Black and White" on my secondary drive (D) i found that there was a segment of it that was linux, so i reformatted the disk, and so lost the game files, this wasn't a problem till i came to re-install it, and was given the option to un-install, so windows must've thought it was still on. i tried to un-install, but was given the error:
    Cannot open E.dll
    i think this is part of the program, and its on the disk, so i tried moving it to where the files used to be, but still the same problem. and i've tried add/remove programs, with the same result
    running: XP Prof SP3
  2. klutch4891
    klutch4891 What's a Dremel?
    4 Feb 2008
    Do you have to uninstall before you can reinstall it? If not I'd just try reinstalling even if it thinks the files are still there.
  3. MRea
    MRea What's a Dremel?
    29 Sep 2008
    You could try clearing it from the registry add/remove list, that may let you reinstall -
    HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Windows\ CurrentVersion\Uninstall and find/delete the key for black&white.
  4. subterrian
    28 Aug 2008
    to klutch4891 : theres no option to reinstall just un-install
    toMRea: thanks ill try this and repost, sounds promising thanks
  5. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    ccleaner may work as well. i'd try that first.
  6. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I can also recommend Baku to help sort out registry problems, and old/invalid entries etc ;)
  7. subterrian
    28 Aug 2008
    CCleaner hasn't helped, BAKU hasen't been tred. and the HKEY idea, is currently in progress
