Other Gamepad for android tablet
Discussion in 'Gaming' started by monkeydud, 21 Dec 2014.
  1. monkeydud
    monkeydud What's a Dremel?
    21 Jul 2010
    Hi all, so I have been looking for a gamepad for my Lenovo A10-70 tablet and can't decide which to get. Really like the look of the Steelseries free, if only it had trigger buttons. One that keeps drawing my intererst is the Nyko Playpad. Seems to have had software issues at start but does anyone here currently use one and if so have they ironed them out? Needs to be portable.
  2. Edwards
    Edwards Minimodder
    8 Oct 2010
    Personally, I'd go with a PS3/4 controller with sixaxis. I had a Moga pro before and though it was good, it doesn't feel as quality as a proper console controller.
  3. monkeydud
    21 Jul 2010
    I has a look at that. Not keen on having to root to get wireless though. Also fancy something abit more portable.
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I'd also go for the DS3/Sixaxis, along with a Gameklip. Yeah, it's a bit pricey for what amounts to a bit of moulded plastic, but it's is durable and I've remounted it to who knows how many cases (3M VHB tape is fantastic), and comes with a not-awkwardly-long OSB-OTG to mini-USB cable that are hard to find elsewhere in the right length, if you don't want to go the wireless route.
  5. monkeydud
    21 Jul 2010
    It's not so much the wireless thing that bothers me. I'm really wanting something as small as possible.
  6. Edwards
    Edwards Minimodder
    8 Oct 2010
    Smallest thing as possible will likely be the Moga Pocket
  7. monkeydud
    21 Jul 2010
    So after 2 nyko playpads turned up dead on arrival, I have ordered a mad catz ctrlr micro! Fingers crossed!
  8. Deblow
    Deblow Minimodder
    12 Dec 2013
    my 1st mistake of 2015 was buying the Samsung gamepad,
    wish id gone for a Mogo
  9. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    +1 for the Moga. Most games with support for gamepads will support the Moga controllers as they have effectively become 'the standard' on Android. And for £9.10 you can't go wrong.
  10. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
  11. monkeydud
    21 Jul 2010
    Have to say very impressed with the mad Catz controller so far. Not tried to many games with yet but works on main ones!
  12. CalmHorizons
    CalmHorizons What's a Dremel?
    9 Dec 2014
    Hardly needed given the ringing endorsements but moga +1 (after much hassle with an Xbox controller I had lying around and a usb to micro usb)
