Windows Games started to stutter...
Discussion in 'Gaming' started by Thaifood, 21 May 2015.
  1. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    got a problem, i havent added any new hardware etc etc. everything is up to date (drivers etc), but all of a sudden my games ranging from bf4 to diablo 3 are stuttering.. the ping is fine, the fps is fine..
    i will have about 20 seconds or more of game play, then it seems to jump around a bit then fine for a bit then jumps around and this goes on and on..
    any ideas?
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Do you use MSI afterburner at all?
    I had this when the Riva tuner server part of it was running, stopped it from starting with afterburner and been fine ever since.
  3. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    yes using msi afterburner.. will go give this a go
  4. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    nope still stuttering.. even taking msi off to see if it has made a difference.. afraid it hasnt
  5. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    Google DPC latency
  6. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    no dps latency issues.. search goes on
  7. dolphie
    dolphie What's a Dremel?
    6 Jul 2012
    Spyware? Run spybot and have it clear your temp files too. Also check task manager and see that nothing is running in the background that shouldn't be, and also check your ram usage.
  8. Thaifood
    Thaifood Minimodder
    24 Apr 2009
    No done a spyware scan, anti virus as well. Going to try a network cable instead to see if it is that. Not sure why I have tried it before
  9. VipersGratitude
    4 Mar 2008
    Tried changing the power saving settings to high performance?
