Overclocking Gaming Build - Bloody Impressed! Thoughts?
Discussion in 'Hardware' started by TechTaku, 3 Feb 2016.
  1. TechTaku
    TechTaku What's a Dremel?
    2 Feb 2016
    I'm really bloody impressed with the overclocking ability. Thoughts on the temperature/score?
    System Specification:
    Motherboard: EVGA Z170 Stinger mITX
    CPU: Intel i5 6600K @ 4.6GHz 1.3v
    Memory: Corsair Dominator Platinum @ 3000MHz (XMP)
    GPU: EVGA 980ti Classified 1518/1901 (+100/+300)
    Cooling: Corsair H100i GTX
    The cooling is a little odd currently as with space restrictions in the case I'm having to mount the normal SP fans outside the case, leaving a small gap between the radiator and have two slim fans inside pushing air through the radiator. It seems to be working, but I might see slightly better results once I purchase a new case using another set of static pressure optimised fans instead.
    Temperature:
    CPU idle: 25-32c
    CPU load (AIDA64 FPU): 51-55c
    Surprisingly, whilst gaming I see similar temperature results to the stress test, which I thought was quite odd. Not sure if I should be worried?
    http://i.imgur.com/B2eEtXh.png?1- Firestrike Score
  2. SuperHans123
    SuperHans123 Multimodder
    27 Dec 2013
    Candelabra
  3. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Try running linpack (Intel Burn Test or LinX) to see how hot your CPU gets under full load. Not many programs stress the CPU like linpack does.
  4. Vault-Tec
    30 Aug 2015
    Asus Realbench 2.4+
