Other Gaming laptop
Discussion in 'Hardware' started by balatro2005, 16 Jun 2011.
  1. balatro2005
    balatro2005 Minimodder
    19 Sep 2009
    Hi have been asked to recommend a gaming laptop but to be honest im not sure what the best ones are. I would guess that the new AMD laptops will be reasonably good but have not seen any yet.
    screen size 15" +
    Budget £500 or less
    Thanks.
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Look at the Dell XPS series. They are quite fancy.
  3. balatro2005
    19 Sep 2009
    Xps range starts at £550 so its out. currently looking at a HP Pavilion dv6-6001sa 15.6" Laptop.
    Has this graphics card AMD Radeon HD 6470M 512mb any one know how these compare to intel graphics ?
  4. bagman
    bagman Minimodder
    18 Apr 2009
    Don't get a Hp laptop they are the worst built laptops on the market.
    Look on the dell out let site there you can pick up a decent 15" XPS laptop with a i3, 3gb, 320b hdd and a 420GT for just under £500
    Also here is a comparison of all the laptop gpu's http://www.notebookcheck.net/NVIDIA-GeForce-GT-420M.35837.0.html
  5. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Some decent Dell offers can be found here:
    http://www.dmxdimension.com/
    The Insirion 15(R) with i5 2410 & GT525m is a good base for £579ish. A little over budget but has a strong CPU and decent enough GPU (enough for 1366x768 and medium settings in most games).
  6. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    I'd agree against HP. But sadly, with that budget you're just a bit short of the good stuff. Especially for "gaming", if you could go to at least 600ish you'd have an easier time.
