Motors Garmin Sat nav not enough power
Discussion in 'General' started by CrapBag, 23 May 2020.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I have a Garming Nuvi 55LM sat nav. Had it for a few years now but always ran it off of the included charger.
    A few years ago I changed the cogar sockets in my my car to dual usb sockets, one outlet was 1A and the other was 2A.
    My sat nav would only work properly if I had it plugged into the 2A outlet otherwise it would shout at me telling me to use the provided power supply as it wasnt getting enough power. This wasnt a problem due to having the 2A.
    I also found a way to route the cables through the dash to the sat nav on the windscreen so i didnt have cables everywhere.
    So I change cars and started using the provided charger again but this is a pain as the nearest cigar lighter is directly in front of the gear stick so i keep punching it.
    I decide to do like i did before but its harder to change the cigar sockets to usb so i purchased one of these its supposed to be 2A so i thought id be fine but nope its moaning about power again.
    I figure the kit might be faulty or under powered so i send it back and order one from ebay that says 2.4A and again it still doesnt do the trick.
    The strange thing is on the provided car charger it says it only has a 1A output.
    Anyone got a clue as to what might be going on.
    My next step is to dismantle the car charger (i have 2) and hard wire the fuse box adaptor and the earth terminal to its pcb and run the sat nav off of that.
  2. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I could remove the 2 usb cigar sockets from my old car and do just that, they are pretty much the same thing, then use the fuse box adaptor as it has a bullet socket on it..
    I hadn't thought of that thanks.
  4. play_boy_2000
    25 Mar 2004
    A crummy washed out pic to better show the mod I made to my car. I was swapping out my stereo a few years back and noticed that there was a ton of empty space under the dash to run wires and put in the outlet. It beats the hell out of messy wires running everywhere for my dash cam and GPS.
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    That's kind of what I did but I had a 7th speaker on my dash which had enough space in the grille for a cable to pass through then drilled a small hole in a dashboard cubby hole right next to my converted cigar lighter.
  6. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Ah right, so you connect the power to the wires for the speaker and when you want to use it you play an audio cassette with an AC waveform on the A side and DC on the B, and vary the voltage with the volume control?
    Gareth Halfacree likes this.
