News Gigabyte and VIA show off DDR converter
Discussion in 'Article Discussion' started by WilHarris, 8 Nov 2005.
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
  2. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    Is there any logic on the PCB Wil? It just looks like a pin-converter to me. I guess since the chipset supports both DDR and DDR2, maybe that's all it needs...
  3. img
    img Minimodder
    23 Oct 2001
    i think im missing something. they have done the duo boards for a while with both ddr1 and ddr2 slots on the board
  4. KriTip
    KriTip What's a Dremel?
    14 Sep 2004
    I've seen PC133 and DDR combos, but not a ddr1/ddr2 board, got a linky img??
  5. Guest-16
    Guest-16 Guest
    Yahuh. I saw one a while back for 915 chipsets cause they supported DDR and DDR2.
  6. hughwi
    hughwi Minimodder
    23 Dec 2003
    Awesome, this looks very promising.
    being picky, there is a typo here "seen on in the flesh until now" - needs an e on the end of on(e)
  7. The_Pope
    3 Jul 2003
    That's not being picky mate - there's correct, and incorrect. We do try to maintain a high standard - some people think it doesn't matter just because it's the Internet. Thanks for the heads-up.
  8. Firehed
    15 Feb 2004
    Quite a few 915 boards have both, in fact.
    A bit pointless imo unless it's under $10, or else you're really just paying more to prolong the inevitable.
  9. Guest-16
    Guest-16 Guest
    Yea some had both onboard, but it takes up PCB space. Also, the DDR slots tended to be more inefficient than the corresponding DDR2.
  10. pman
    pman What's a Dremel?
    26 Jul 2005
    How long before ECS come up with a similar idea, as they usually are the hybrid people!
Tags: Add Tags
