GIGABYTE GA-990XA-UD3
Discussion in 'Gigabyte' started by AoE, 14 Dec 2011.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Does this board have ACC (Advanced Clock Caliberation)? in BIOS?
  2. AoE
    4 Oct 2011
    Is this available with any new BIOS Updates or?
  3. DevilsShooter
    DevilsShooter What's a Dremel?
    3 Nov 2011
    says to enable AM3+AMD fx cpu support you have to upgrade the bios, there is a beta one there and a few others which are recent enough. got my info here http://www.gigabyte.com/products/product-page.aspx?pid=3901#ov
    can only see something about easy tune and cloud OC, it has dual bios as well and not too sure about that but I think that would mean you could have 1 original bios and your OC bios ready to switch at a click of a button, dont hold me to that though just guessing.
  4. AoE
    4 Oct 2011
    cheers more helpful than the gigabyte staff
  5. Nonforgo
    Nonforgo What's a Dremel?
    19 Dec 2011
    that right
    yes, that right my friend :)
  6. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    I'd have to warn you though; Should you get a 1.0 Revision board; it will not play Saints Row 3 or Portal 2, even with the latest F6f beta bios. It does appear that the 1.1 and 1.2 version boards are capable of working with the application. Sadly I can't ask gigabyte at this time, as their entire support staff is off till the 3rd of Jan.
  7. bulldogjeff
    2 Mar 2010
    By ACC if you mean do you have total control over every setting, then the answer is yes.
    The dual Bios is a fail safe so if you bork one with a dodgy update then the other will kick in. It's totally inaccessible and it set to factory defaults and can't be altered in any way.
