Hardware Gigabyte Odin GT 800W PSU
Discussion in 'Article Discussion' started by Tim S, 15 Oct 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    I like the idea of the monitoring abilities, however I feel I prob would not use the temp probes due to already using other solutions, what does apeal though is the Wattage metter, which gives a nice indication of the idle and load levels, this can prove reasureing for people whom have thier pc's stacked with gear, so they may see just howmuch of the PSU is in use.
    I like the features, but the novelty will wear off pritty fast I think, once checked that the psu handles all the kit you have on load, I dont see much of a reason to keep checking it, thus negating one of the reasons for getting the PSU.
  3. Guest-16
    Guest-16 Guest
    It's like CPU (or whatever else) temps though - once you know it only hits 60C it isn't going anywhere, so then why do people continually run it in their taskbar? :)
  4. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    In case something breaks/comes unplugged.... also, if i know that something should be at 30 degrees, and when I look I see 35, I know that my case needs cleaning.
  5. MilkMan5
    MilkMan5 Yeah man...
    11 Jul 2007
    Gigabyte actually have a range of PSU, the GT is just one of the series.
    For example,
    The ODIN GT comes with the monitoring software
    The ODIN Pro does not, and is a standard PSU
    The Superb range – really just a budgde PSU
  6. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    thats a very impressive results!
  7. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    im pleasantly surprised may be worth a further look for my build next month
  8. FR34K
    FR34K What's a Dremel?
    1 Feb 2007
    friend of mine actually got this same one(or horribly similar) a few months ago, and I got to help him set it up...it's rather nice. 4 computers running at the same time with other things running in one room isn't too great of an idea though...ended up with a couple surges.
  9. Guest-16
    Guest-16 Guest
    I completely forgot to drop in my photos of the actual testing recording the voltages etc. I'll sort them out and drop them in for verification. :thumb:
  10. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Hmm.. i like it.. just not that high a wattage. need a smaller one, say 620W.
  11. MilkMan5
    11 Jul 2007
    I guess the idea is there – something different.
    The software is about giving you control of your PSU, no other PSU in the market can do this.
    Motherboard manufactures offer software O/C features, but I don’t think many people actually use it for O/C.
    So if you can control your M/B, then why not you’re PSU!
    :p
  12. fearz
    fearz What's a Dremel?
    19 Nov 2007
    Gigabyte Odin GT 800W PSU Power Tuner Error..Please HELP.
    Hi, I just bought that powerfull PSU today. There is this software Powertuner (to have full control over the PSU) came along with it, It doesn't seem to work neither on Vista 64 nor XP 32.
    When I load it it says ****Unsupport Power Type****
    and the program close.
    I connected the usb from outside (using the interface) and from inside.
    Tried download the version on their website, still same error...
    PC Specs:
    Windows Vista Ultimate 64bit
    Gigabyte M59-SLI-S5
    Gigabyte 3D Galaxy 2 Liquid Cooling
    AMD Athlon 6000+ X2 64bit Overclocked @ 3.3 Ghz
    nVIDIA XFX 8800 Ultra Extreme Edition
    Creative X-fi Elite Pro
    4x 1GB DDR2 Kingston 800 MHz
    1x WD 500 GB SATA2
    1x Toshiba 150 GB SATA2
    1x Seagate 150 GB SATA2
  13. Guest-16
    Guest-16 Guest
    Well it should work in 32bit XP, it worked fine in 32bit Vista, I can't say the same for 64bit.
    Tried other USB ports or internal ports? Otherwise, return it and get a new one?
  14. MilkMan5
    11 Jul 2007
    As far as I know, the P-Tuner software only works on 32-bit Windows.
  15. Kilometrico
    Kilometrico What's a Dremel?
    9 Oct 2009
    Works on perfectly on 64-bit vista, have been running it for about 3 1/2 weeks now
Tags: Add Tags
