News Gigabyte X58A-UDP7 shot leaked
Discussion in 'Article Discussion' started by CardJoe, 15 Apr 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Krikkit
    21 Jan 2003
    Looks like a good board for a serious folding machine - one of these and seven GTS250's? Pretty good combo.
  3. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    For when I absolutely, positively have to use 7 watercooled GTX480's .. Oh wait.
  4. GFC
    GFC What's a Dremel?
    7 Nov 2008
    I can't even imagine how MANY power supplies you'd need for that. But I'd sure love to see one system like that. ^^
  5. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    When 4 PCI-E slots just isn't enough.
  6. Platinum
    Platinum What's a Dremel?
    25 Jun 2001
    Shame it wont fit in most chassis though, that things longer than the standard ATX spec.
  7. ev1lm1nd666
    ev1lm1nd666 What's a Dremel?
    23 Apr 2009
    The ATX Spec size mobo's have the space for 7 expansion slots, they just used 7 PCI-E slots in this one.....
  8. DBA
    DBA I do my modding with a spoon
    18 Feb 2009
    Well.. look how low the PCI-E slots sits, on most (or atleast some) boards the top PCI-E slot sit right under the IO ports.
    It sure won't fit my chase, but who would use a standard case when they can afford/have the need for such a board.
  9. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    Will be happy when we finally have nothing but PCIe slots....
  10. Unknownsock
    Unknownsock What's a Dremel?
    13 Jul 2009
    PCI-E mounted CPU ofc!
  11. Platinum
    25 Jun 2001
    What DBA said, this board could potentially have 9 slots, its defiantly longer than the ATX spec.
  12. wyx087
    wyx087 Multimodder
    15 Aug 2007
    if you look closely, it's got 4 holes on the right, with the 3rd one next to the SATA connectors being ATX standard. so the last 3 PCIe slots are not meant to be there, they are not ATX standards.
  13. Drexial
    Drexial Minimodder
    28 Jul 2005
  14. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Genuine question - Can you get single slot cooled GTS250 cards? It looks like to use all seven slots you can't use double slot cooled cards.
  15. xMathiasD
    xMathiasD What's a Dremel?
    15 Mar 2009
    its ud9 not ud7 ^^ - there is a biiiiiiiig 9 on it! :D
  16. Diosjenin
    Diosjenin Thinker, Tweaker, Et Cetera
    14 Jul 2008
    Not directly, but you can get single-slot full-cover waterblocks and single-slot GeForce PCI brackets...
  17. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Or use PCIe extenders?
  18. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
    Are you sure is not a '6'?????
    Looks like one (i mean 5) to me
  19. Farfalho
    Farfalho Minimodder
    27 Nov 2009
    I noticed the 2x 8 pin socket, how much power does it need?
    I like the colour scheme, although not overwhelming, it's different and still pleasant.
    I can't figure out what will be the number after UD... If only there was a giant clue on the board, anywhere, it could be on the board on something also big... :p
  20. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    It's definitely a 9, it would be stupid to have a 6 when 'Gigabyte' is written above it.
    When can we get enlarged pictures on news stories??
Tags: Add Tags
