News Gigabyte Z590 Aorus Tachyon motherboard available shortly
Discussion in 'Article Discussion' started by bit-tech, 15 Mar 2021.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Paradigm Shifter
    10 May 2006
    That slot layout is terrible.
    Arboreal likes this.
  3. wyx087
    wyx087 Multimodder
    15 Aug 2007
    I guess click to enlarge is like the Portal cake?
  4. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Agree. Must be due to the 3x M2, in which is overkill. Why would you even need more than 2?
  5. Paradigm Shifter
    10 May 2006
    I can think of a situation I'd want three (work related) but I don't know if any board supports NVMe RAID5, so it's a moot point anyway. I'd rather they put them on the back, to be honest, even if it does make replacing them a bit more of a faff. The primary reason I dislike the slot layout is that as soon as you put a GPU in, you lose two slots... because what high-end modern GPU is single slot? Dual GPU? All PCI-E expansion gone. Unless they've done something very unusual and the primary slots are actually the 2nd and 4th slots (from the top in the publicity shot)... but I don't think that very likely.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    But in those situations you'd probably also be looking at a HEDT board with plenty of real PCIe lanes (So you can stuff said m.2 drives into PCIe adapter cards).
  7. Omnislip
    Omnislip Minimodder
    31 May 2011
    Isn't the idea of a board with this number of power phases that you really ought to go with a custom loop, so single-slot GPUs are fine?
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    Omnislip likes this.
  9. Paradigm Shifter
    10 May 2006
    In an ideal world, where I don't have to choose between two systems (and the ability to do two things at once) or one (and have people complaining at me when I explain that their work is in the queue) I would agree.
    That said, any board like that, I'll be too busy stuffing GPUs in to worry about (or fit!) a PCI-E NVMe expansion card.
    The only semi-reasonable single-slot GPU I can think of right now is a Quadro RTX 4000 - there was also a single slot GTX 1070 and it's Quadro equivalent, but even when new finding one was... not easy. The Quadros are fairly easy to find, but they're workstation GPUs so you don't half pay for the pleasure.
Tags: Add Tags
