Cases Girlfriend Friendly Cae?
Discussion in 'Hardware' started by ResCyn, 9 Dec 2011.
  1. ResCyn
    ResCyn What's a Dremel?
    23 May 2011
    *Case
    Hey all,
    Just looking for some suggestions as to case for the Mrs. My spare Antec 300 is too big and too black apparently so I need something smaller and ideally silver/white - I may be able to get away with black if it's dinky enough. Not looking to break the bank as it's only an i3 going in there with a low-end card for the Sims.
    Thanks in advance.
  2. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    Lian Li A05NA?
  3. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Core 1000?
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Let the Mrs. pick it out herself? Of course narrow the search criteria first to only brands that are not garbage.
  5. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    If it's MATX, try the FT03? I don't know what your budget is though...
    Failing that, the TJ08-E, Lian Li A04, A05-NA, SG-03 or Lian Li V351-A would be good bets.
  6. Tangster
    23 May 2009
    Pink NZXT phantom?
  7. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    thats quite big. Bigger than the antec 300.
    Hmmm do they do a mini fractal design in white? Would be sweet. Or you could do a ft03 with pink/purple lamps under the skirts
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
  9. Arednel
    Arednel What's a Dremel?
    13 Oct 2011
    Help her mod a case? My boyfriend had a case a friend spray painted red and black with Sith designs on.
    Personally I'd hate a pink case, I'm going for a black fractal to match all my other black gadgets.
  10. short1uk
    short1uk Minimodder
    20 Sep 2011
  11. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    if you can get away with the Matx case and have the budget, +1 for the FT03, bloody awesome case, expensive but worth it!
  12. ResCyn
    23 May 2011
    I'll be showing her the suggestions in here ;)
    An Arc Mini (rather than Define) was my first thought but they don't do them in white.
    The Lian Li A05N would be my choice so far but doesn't seem to be available in the UK in silver. It may be a little over budget even in black as I'm looking around the £40-50 mark. It may have been helpful had I said that in the first place :duh:
    I've never had any experience with MATX but that could be an option. Happy for suggestions for MATX cases and a decent MATX SB mobo too!
  13. Guest-44432
    Guest-44432 Guest
    If she is Girly Girly, then this would be perfect.
    Link
  14. murraynt
    murraynt Modder
    6 Jun 2009
    White antec p180 mini? Or a fractal design mini
  15. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    champagne anodized lian Li are sexy as hell
  16. Marvin-HHGTTG
    10 Oct 2010
    Cost a fortune and are rare as the proverbial though...
  17. el2k
    el2k Modder
    18 Jan 2010
    I have a pink phantom, and i fu#king love it.
  18. Bloody_Pete
    11 Aug 2008
    See, girls love it...
    :p
  19. Lord-Vale3
    Lord-Vale3 His Tremendousness
    1 Dec 2009
    She's a girlfriend. Just buy something really expensive. They love expensive things.
  20. GiggleStool
    GiggleStool What's a Dremel?
    23 Nov 2011
    If you decide on a nice size case but the colour isn't right. Then maybe you could get it sprayed pink.
    Or for a less time/money consuming aproach you could get some vinyl laser cut decals that make it a bit feminine. Ive seen some kool pink/white swirls/flowers/buterflys in some shop, they would fit nicely on the side panel.
    Just a thought
