Planning Glass Chassis Machining
Discussion in 'Modding' started by kuala, 1 Sep 2014.
  1. kuala
    kuala What's a Dremel?
    24 Jun 2014
    Hi guys.
    I am looking into having 3 fairly large (650mm approx) sheets of glass cut into rhombus/rhomboid shapes for the window and a large part of the construction of a scratch build I may do.
    Does anyone know of anywhere I could have these cuts done cleanly in Kent/London?
    Any help would be much appreciated!
    Thanks, Kuala
  2. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    Cutting straight lines in glass is pretty straightforward. I've trimmed down mirrors before with a glass cutter. Glass cutters are inexpensive and I'm sure there are guides out since you've never done it before. You just score a line in the glass with a cutter and snap the piece in two. You may want to practice a bit with smaller pieces but as long as the glass isn't too thick it's not difficult.
  3. asura
    asura jack of all trades
    22 Apr 2009
    With sheets that size I'd prefer a professional to make the cut - dig out your yellow pages and look for glaziers and people who do mirrors (whatever the hell they're called) as they'll generally give you a bevelled edge as well which is a boon for handling.
  4. kuala
    24 Jun 2014
    Similarly to what asura said I am not confident making such big cuts on somewhat thick glass with chances of micro-cracks and such.
    Yellow Pages are probably a good start but I was wondering if anyone knew/could recommened anyone who they may have used before/know.
    Thanks for the out anyway!
    P.S. Baby Moon turned out beautifully!
  5. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    The below company is both in Kent AND (Greater) London :D
    Chelsfield Glass Ltd
    Glass Supplier in Orpington
    19 Windsor Drive
    Orpington
    Kent
    BR6 6EY
    T: 01689 862 419
    You could give them a bell and have a chat. The business has been there forever and must be fairly decent to have weathered the recession. Think my family have used them a couple of times over the years.
  6. kuala
    24 Jun 2014
    Thank you very much Fizzban!
    When I get the project going (may be some time) I will contact them.
    Thanks again!
