News GlobalFoundries announces TSV tech on 20nm
Discussion in 'Article Discussion' started by brumgrunt, 27 Apr 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Bede
    Bede Minimodder
    30 Sep 2007
    I can see why they abbreviate it, 'through-silicon via' is one of the worst descriptions I've ever seen! Is there likely to be much demand for TSV soon? I would have thought it introduced more complications into chip design.
  3. Jehla
    Jehla Minimodder
    8 Jan 2010
    What would you call it? Seems perfectly simple to me, a via which goes through the silicon. I am assuming these via are used to connect to the "system" under the silicone and not to other layers within the silicon.
  4. Alecto
    Alecto Minimodder
    20 Apr 2012
    Actually the vias can can connect to anything. When you stack two devices you can only reach the top layer of bottom device but with TSV you can implement a bus, not unlike the busses on PCB, that multiple devices can attach to (for example the PCI-e hub, the CPU, the graphics core and the memory for the latter two could all be packaged in a single stack, taking up much less surface area, thermals permitting).
  5. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    And the Yields will be big Q
Tags: Add Tags
