Development $GLOBALS and custom tags
Discussion in 'Software' started by ManStrike, 2 Jul 2006.
  1. ManStrike
    ManStrike What's a Dremel?
    29 Jan 2002
    I’m working on building custom tags for php, so far all has been going well. I have made a set and a get tag.
    input
    PHP:
    <rmpw:set var="$bar">Hello World</rmpw:set>
    html>
    head>
    title><rmpw:get var="$bar"/></title>
    rmpw:set var="$bar">Some new text</rmpw:set>
    head>
    body>
    p><rmpw:get var="$bar"/></p>
    body>
    A global variable called $bar is created with the rmpw:set which can then be accessed by the rmpw:get. This all works fine, however if I try and change the value of $bar with some new text I cant seem to replace it.
    output
    Code:
    <html>
    <head>
    <title>Hello World</title>
    </head>
    <body>
    <p>Hello World</ p> <!—should be ‘Some new text’ -->
    </body>
    I’m using $GLOBALS to store the variables but it only seems to effect it locally and I’m all so using ob_start which might be effecting it.
    PHP:
    function globalSet($variable$value) {
    $add = array($variable$value);
        for (
    $i=0$i count($GLOBALS); $i++) {
            if (
    $GLOBALS[$i][0] == $variable) {
                unset(
    $GLOBALS[$i]);
                break;
    array_push($GLOBALS$add);
    function
    globalGet($variable) {
        for (
            if (
                return
    $GLOBALS[$i][1];
    any suggesting on why I can’t update my $GLOBALS would be appreciated
