Displays Glossy screen question
Discussion in 'Hardware' started by Vault-Tec, 25 Dec 2016.
  1. Vault-Tec
    30 Aug 2015
    OK, so is a glossy screen the actual LCD or is it something they put over the LCD?
    I'm wondering if my scratched monitor would be easily repaired (by using some 1mm plexi) or if it's FUBAR and I should try drastic measures (like polishes and compounds).
  2. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    The only glossy screen I have is on a 27" iMac, so may not be the same as other monitors, but. There's a glass panel in front of the screen which can be removed and whilst this does reduce the 'glossy-ness' of the screen it is still far glossier than any other monitor I have!
    I would guess it's just a very thin overlay on the actual panel itself, whether this could be polished or not I've no idea though.
  3. Vault-Tec
    30 Aug 2015
    Thanks. Well I guess I will get bored enough at some point to take it apart :D Hoping it's just a cover and not the screen itself.
  4. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    I've repaired dozens LCD's by sanding out scratches with high grit paper and re coating the entire screen with anti glare spray (hard to find anymore, as it was marketed for CRTs). It took a lot of effort and the results occasionally didn't come out perfect, so only do it as a last resort.
