Small Form Factor Going from ATX -> mATX
Discussion in 'Hardware' started by el2k, 3 Aug 2011.
  1. el2k
    el2k Modder
    18 Jan 2010
    Hey,
    I'm planning on going from ATX to mATX due to me moving my PC around a lot and just generally wanting more desk space.
    I'm pretty happy with my current setup (see sig) and was thinking I could just get a new case and motherboard?
    The cases I was thinking of are the Lian Li PC-V354B, the P180 Mini(If i can find the white version anywhere) and the Armor A30.
    Basically my questions are as follows:
    Which do you think would be the best case overall for me to buy? Taking into consideration the price and the ability to cool my GTX480 and maybe fit the H50 in?
    What motherboard would you replace my sabertooth with?
    Any help greatly appreciated as I've been racking my brain about this for a few days now.
    Regards
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    What about the Lian Li PC-A05? It is about the same size as an mATX case but fits ATX boards.
    You would have to mod the roof panel to cool the GTX 480 and the airflow moves back to front but it is an idea...
    marsbarman has one that he is thinking of selling with a pre-modded roof panel (I think).
  3. el2k
    el2k Modder
    18 Jan 2010
    I hadn't thought of this, However I would ideally like to go as small as possible whilst still being able to cool my rig well enough.
  4. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    The Fractal Design Arc Mini gets good reviews, looks pretty good and seems to have adequate cooling. Maybe an option?
  5. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    I love that case, however there is smaller MATX cases out there, it all depends what the OP wants..i was thinking about putting my server in that Arc Mini after seeing it in last months CPC
  6. Fingers66
    30 Apr 2010
  7. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Still vote for the Arc mini over those two above ^. The only down side is that it does look a little plain...great cooling however according to CPC
  8. el2k
    el2k Modder
    18 Jan 2010
    I'm looking for as small as I can go ideally with enough cooling potential to keep my system stable.
    CPU isn't overclocked at all right now as I play all the games i want just fine.
    Idles around 25 and on load maybe 40.
    GPU idles around 52 and upto 70-80 on full load.
    However my current case is a beast for cooling.
  9. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    The thing is with going MATX is you have to sacrifice something...take a look at that Arc mini, i know i keep going on about it but it has amazing cooling potential !
  10. Hereisphilly
    Hereisphilly What's a Dremel?
    8 Jul 2010
    If you dont mind spending the money, Silverstone FT-03! Stepping down go to the arc Mini, or stepping down again in price, the NZXT is great little portable case
  11. el2k
    el2k Modder
    18 Jan 2010
    Thanks for all the help on cases.
    What about motherboards?
    Any recommendations for 1156 mATX boards? That shall see me good for a year or so.
    Cheers
  12. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    It seems that P55 motherboards have become fairly scarce now with the rise of Sandybridge; this is the only mATX board I could find on Scan, apparently it's the Q57 chipset which I haven't even heard of:
    http://www.scan.co.uk/products/asus...)-ddr3-1600(oc)-sata-3gb-s-sata-raid-microatx
    However Ebuyer has these two boards which seem much more solid, both very different in price though so you can take your pick:
    http://www.ebuyer.com/179794-asus-p7p55-m-p55-socket-1156-8-channel-audio-matx-motherboard-p7p55-m
    http://www.ebuyer.com/180554-asus-m...rs-p55-socket-1156-8-channel-maximus-iii-gene
  13. faugusztin
    11 Aug 2008
  14. Fingers66
    30 Apr 2010
    If you go for a Lian Li PC-A05 case, you can use an ATX motherboard.
    mars-bar-man has just bought a new case so I reckon his PC-A05 (with modded roof panel) will be up for sale soon.
  15. Guest-16
    Guest-16 Guest
    I run a Lian A04 w/ GTX480, but it's watercooling is mostly external. It didn't cook inside when it was aircooled but it certainly wasn't quiet and I lost a lot of the disk space by having to remove one of the racks.
  16. GeorgeStorm
    16 Dec 2008
