Modding good 120mm blue fans?
Discussion in 'Modding' started by Sh00ter, 1 Jun 2004.
  1. Sh00ter
    Sh00ter What's a Dremel?
    13 Oct 2002
    got a need for a couple of 120mm bluelit fans, looking around though the akasa'a dont seem to push much air, the antec's only have 3 led's and other dont really give specs!
    wot fans would you recommend for a good cfm to noise ratio? (they will be through a fanbus so noise not that important coz mostly they'll be running 7v)
    you input appreciated, sick of bouncing from site to site looking!
    :D
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Crazy PC has a 4 LED blue 120mm fan.
    SVC also has a 4 LED blue fan at a lower price but it is out of stock for now - you can try to get an ETA on it though.
  3. verse
    verse What's a Dremel?
    28 Mar 2004
    I don't think SVC will ship internationally :eek:
  4. Xiachunyi
    3 Nov 2003
    Oh, sorry - I thought chatham was just a made up name, or is it? :worried:
  5. Blood
    Blood What's a Dremel?
    4 Jan 2004
    I think maplin only does the 120 mm blue asaka ones, a bit pap i think too , why dont u do some crazy effect with ur own made ones?
  6. Mecha_Mindslayer
    Mecha_Mindslayer Banned
    23 May 2004
  7. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    If the antec fans are powerful enough, buy thouse and put your 4 of you own LED's in :)
    No it's a place in the UK :duh:
  8. Xeroxx
    Xeroxx What's a Dremel?
    29 May 2004
  9. TMM
    TMM Modder
    12 Jan 2004
    the antec ones are weak.
    i've got these in my case:
    http://www.vantecusa.com/p_sp_80uvled.html
    36cfm, 34db
    their "sweet spot" is around 9v, still pushes alot of air, but a heck of alot quieter than the full 12v.
    edit: opps they are 80mm :blush:
  10. Sh00ter
    13 Oct 2002
    thanks for all the replies, i twas being very lazy minded - i hadnt even thought of wacking me own led's in, will most prob go down that route :D
    good links as well, always good to see some new (to me) places to buy
