News Google adds Trojan protection to Safe Browsing
Discussion in 'Article Discussion' started by Combatus, 15 Aug 2014.
  1. Combatus
    16 Feb 2009
  2. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    about time they started doing this and PUP websites what they need to do is Implement Bad website as Phishtank and other lists ignore scam websites (cold callers who pretend to be from "windows Support" there are still 2-3 websites i have on my list that are Not been blocked by any browser the sites are 5 years old)
    they should sort out there advertisers first, put itunes in and you see the PUP links (say itunes.randombdownload.com) installs 3-5 pieces of unwanted software and then installs itunes
    antivirus softwares should have been aggressive targeting PUP for long time now, coming to a computers that has 5-20 unwanted softwares installed and the antivirus just ignoring it
    only AVG and Avast do it, but ONLY do once you have Enabled it, its Disabled by default
    AVG its under the real time scanner bit
    http://support.avg.com/SupportArticleView?urlname=What-is-Potentially-Unwanted-Program-PUP
    avast you need to enabled in under active protection > sensitivity for web, mail and scanner
    http://en.kioskea.net/faq/15731-avast-enable-detection-of-potentially-unwanted-programs-pups
    for normal users PUP should be enabled as most people cant make a informed decision on what is bad or good (for Adv users most prob want it off)
  3. fodder
    fodder Minimodder
    20 Feb 2009
    and most will just click through to the dodgy site anyway, then call the family tech support as their computer is running poorly. :/
  4. Nexxo
    23 Oct 2001
  5. theshadow2001
    3 May 2012
    You beat me to it Nexxo!
  6. Nexxo
    23 Oct 2001
    I couldn't resist such a perfect setup. :p
  7. Jimbob
    Jimbob Minimodder
    2 Jul 2009
    Does that mean it will start to block adobe.com? Whenever you install Adobe Reader it tries to also install Google Chrome too unless you specifically un-tick the boxes.
Tags: Add Tags
