News Google releases Fuchsia OS details
Discussion in 'Article Discussion' started by bit-tech, 12 Apr 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Mr_Mistoffelees
    26 Aug 2014
    No doubt gathering information about everything users do and using the information to serve targeted advertising will be a primary thrust of Fuschia, probably with some means included to prevent the use of adblockers.
  3. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    zircon must be like vmware's hypervisor in ESXi. it's not linux, but it does have busybox on top of it that makes a lot of newbies think it is linux.
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Fuscia, like Android and Chrome OS, is open source. If you think they're doing Nefarious Tracking Things, you can not only highlight the code doing it and bask in your global fame, you can also remove it and compile your own version omitting it.
    Or we can keep our paranoia in the realms of reality rather than MOON LANDINGS FAKE world, and simply not use the Google Services Framework if you don't want to interface with Google's services.
  5. Gareth Halfacree
    4 Dec 2007
    It's not a hypervisor, but a microkernel; two very, very different things.
  6. Mr_Mistoffelees
    26 Aug 2014
    Keep your tin hat on.
    BTW, how else do you think they are able to send you targeted advertising?
    BTW 2, my original comment was driven by cynicism.
  7. edzieba
    14 Jan 2009
    For Google in general?
    - Webbug tracking (Google Plus buttons, Adwords)
    - Tracking analytics (ubiquitous Google Analytics)
    - Tracking cookies (e.g. Gmail login, Doubleclick)
    - Logins to other sites using Google account
    - Search terms
    - Location tracking (if turned on in Android) via GPS and local WiFi networks
    As Chrome, Chrome OS, Android, Fuscia, etc are open source, if you want to use them without the Google components then doing so is trivial even if you don't ever want to look at the source yourself, e.g. Chromium, AOSP, etc. It's not some ineffable property of the OS.
Tags: Add Tags
