Watercooling GPU Blocks
Discussion in 'Hardware' started by voids sleet, 24 Nov 2012.
  1. voids sleet
    voids sleet What's a Dremel?
    3 Sep 2009
    hello there bit-tech people
    right so I have a new rig all up and running and it turns out i've been a nonce with the gpu's, basically i have not done my research and dived in head first :duh:
    i have gotten me 2 xfx double d 7950's with a part number of FX-795A-TDJC (or here its is http://xfxforce.com/en-us/Products/...-HD-7000/AMD-Radeon-HD-7950/FX-795A-TDJC.aspx)
    right so does anyone know of any full blocks that work with this card or has anyone had any experience with it.
    failing that, im looking for some advice on a universal block and anything i would need for that.....
    The spec's for the rig is (going to go update my sig)
    mobo - x79-ud3
    cpu - 3820
    ram 16gb LP corsair Vengeance
    gpu 2x xfx 7950 dd
  2. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    A good start is always the cooling configurator
    From there you can look up any part and see what blocks EK has for it.
  3. voids sleet
    3 Sep 2009
    thanks for the link, just gone into it and it comes up with 13 universal blocks and a HD7970 Cu Adapter
