I downloaded the gpu client from the stanford folding@home website What i downloaded was called Windows: V6 GPU2 ( clients Windows XP/2003/Vista/7 GPU2 System tray client (installer msi) After downloading i installed it without a problem. Now when i try to run it i get a message saying "At present your GPU is not supported or you need a current driver. You may wish to consider running our standard client, which you can download at folding.stanford.edu." And then it doesnt start the client How could i solve this problem? I have an HIS 5750, Q6600, 4GB DDR3. Running win 7 64bit
AMD cards do not give good results with GPU2. You should get better results with the v7 (beta) client.
i downloaded the V7 and now its working. But i only have the GPU client running. Previously i downloaded the SMP client from this page http://folding.stanford.edu/English/DownloadWinOther It was called Windows XP/2003/Vista/2008/7 SMP2 client console version 6.34 (32-bit or 64-bit) Now if i want to run both the GPU and the CPU clients should i run the V7 for the GPU and the SMP which i downloaded? OR can i uninstall the SMP client i have and install the SMP client into the V7 as mentioned in the "Multi-client Installation - Adding slots (Expert and above)" section as mentioned here? http://folding.stanford.edu/English/WinGuide
