Graphics GPU for 1280x1024
Discussion in 'Hardware' started by Da_Rude_Baboon, 15 Nov 2011.
  1. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Hi All,
    I am going to donate my old PC to my nephew but it will need a GPU upgrade. I'm looking for the cheapest GPU that will play modern games, luckily he only has a 17" monitor so it wont need to be too powerful. Current spec below.
    Q6600
    4GB RAM
    8800GT
    Thanks,
    DRB
  2. bagman
    bagman Minimodder
    18 Apr 2009
    A 8800GT will be able to play anything at that resolution, and a lot of games on max. A 450GTS will easily be enough at that resolution, if you want a DX11 card. Or you could a second hand 260GTX.
  3. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Cheapest meaning how much? A preowned 4870 is pretty much the best value GPU you can get currently, costing about £35 if you know where to look. As for DX11, don't bother with cheap GPUs as they simply won't handle the tessellation.
  4. Da_Rude_Baboon
    28 Mar 2002
    £50 would be the top of the budget.
  5. murraynt
    murraynt Modder
    6 Jun 2009
    A second hand 5770?
  6. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    You can get him a GTX275 if you are happy with DX10; 5770 is a little above budget at £60ish.
  7. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    +1 on the GTX275. Will be awesome at 1280x1024.
  8. jake9891
    jake9891 Loves Internet Shopping
    4 Oct 2008
    personally I would keep the 8800GT, I've been playing games with it on 1920x1080 resolution and they still looked fairly good
  9. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    I had an 8800GT briefly and Test Drive Unlimied (first one from 2006) crippled it at 1920x1080. It's a good card, but definitely showing its age now. :)
  10. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    my 8800GTS 640MB plays BF3 at low-med settings at 1680x1050.
    u should check with ur nephew and see what games he like to play first IMHO.
    but yeah, a 275 would wipe the floor at 1280x1024.
  11. Da_Rude_Baboon
    28 Mar 2002
    At the moment he doesn't really play anything as he is a console gamer. I have gifted him L4D over steam so I could play that with him but he complained he needed a gamepad. Kids today. :rolleyes: I'll stick with whats there and see how he gets on.
  12. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    Dose the motherboard do sli?
  13. GeorgeStorm
    16 Dec 2008
    At that res the 8800GT should do fine I would have thought, if not, the 260/275 are both fantastic cards.
  14. The Protocol
    The Protocol What's a Dremel?
    6 Sep 2011
    I second that but a 5750 single slot would be better I think
  15. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    I suggest you buy nothing, as the 8800GT will be more than adequate for such a low resolution. If it still works then there is no reason to look elsewhere unless he finds he wants to take PC gaming more seriously and buy a new monitor. No point spending money before you need to.
  16. Tangster
    23 May 2009
    8800GT is still an improvement over any console.
    Just saying.
