hi guys i want to take the fan off my VGA card its a all-in-wondoer 8500DV and has no mounting holes by the GPU, so what ever i do i'll end up using two-part thermally-conductive epoxy adhesive. so do i get the Zalman Silent Video Card Heatsink glue-mount ZM17-CU http://www.quietpc.com/uk/vgamb.php#zm17cu or do i go for something a bit bigger that should use mounting holes but just use adhesive and hope it does't pull it off i was thinging something like.... http://www.tekheads.co.uk/s/product?product=604232 now the weight is ... 120g for the zalman and its 220g for the Aerocool VM-101 what do you guys think thanks edit: oh yeah by the way this computer is in a 19" rack so the mobo is flat on the floor of the case(not in a tower) and case has good air flow i think
