Graphics GPU idle 54C
Discussion in 'Hardware' started by silk186, 4 Jul 2019.
  1. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Maybe it's that then. I guess have a bit of a explore and see if you can find where it starts crashing.
  2. Vault-Tec
    30 Aug 2015
    Are you using Afterburner per chance?
  3. silk186
    silk186 Derp
    1 Dec 2014
    I used Global WattMan to adjust the settings. It was running stock before.
  4. GeorgeStorm
    16 Dec 2008
    You shouldn't have to underclock to remain stable with those temps, unless other parts of the card are getting much hotter.
    Do other programs give you more gpu temperature readings? (such as VRM)
  5. Vault-Tec
    30 Aug 2015
    What I meant was don't use afterburner on AMD cards as it stops the fans working properly and all sorts of other problems with Wattman.
    silk186 likes this.
  6. silk186
    silk186 Derp
    1 Dec 2014
    I've never overclocked my GPU before so I'm not familiar with GPU monitoring software but I'm happy to try any recommendations.
  7. silk186
    silk186 Derp
    1 Dec 2014
    I had some free time so I tried playing Subnautica in windows 1080p and it played for a long time but did eventually lock up.
    Since the epic store is crap, I don't know how long I played but it should be around the 30-minute mark.
  8. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    You need to start logging temps etc whilst you're gaming so you can post the parameters at the point of lock up buddy.
  9. GeorgeStorm
    16 Dec 2008
    The fact it takes time to freeze makes me think temperature is still the issue, and you've tried increasing all fan speeds etc?
    Sentinel-R1 likes this.
  10. Sentinel-R1
    13 Oct 2010
    Agree. As I and others suggested, I'd be re-TIM'ing this card as a first course of action, with something decent like Kryonaut that doesn't dry out as fast.
  11. silk186
    silk186 Derp
    1 Dec 2014
    I will try re-timing tomorrow. I have played games in windowed and watched temps and it always freezes at 81C.
  12. Sentinel-R1
    13 Oct 2010
    Even more reason to put fresh, decent quality TIM on then. If you can stop it reaching 81c in the first place with quality TIM, then your problem is solved.
  13. silk186
    silk186 Derp
    1 Dec 2014
  14. silk186
    silk186 Derp
    1 Dec 2014
    So, I opened up the card and cleaned it up. It was actually much cleaner than I expected. once again, I was surprised by how hot the backplate was despite the fact I didn't do anything more demanding then youtube today.
    This video, GIGABYTE RX 480 G1 GAMING - So HOT!! Literally... also says that his card is hitting 80C at stock and that the back plate gets really hot. JayzTwoCents said that his card needed a more aggressive fan profile and more power to hit its rated speed. One thing that is strange with my card is that it doesn't seem to throttle when it gets too hot.
    I was surprised by how little thermal paste was on the original card. It seems that my thermal tape is messed up. What should I buy - thermal pads, thermal tape? Or ... don't bother and slap it back together with new thermal paste on the die?
  15. Bloody_Pete
    11 Aug 2008
    Pads are what you want, non adhesive ones. Aquatuning has a really good selection. Watch out as the thickness is important and can vary across the card.
    After watching his video (love me some Jay), and seeing the tIM, it almost looks like the cooler isn't making full contact with the GPU or there's a design flaw with the cooler. Maybe contact Gigabyte customer service and ask, as it may be a known problem that they have a fix for.
  16. Vault-Tec
    30 Aug 2015
    You can buy new pads but make sure they are the correct thickness or the card will bow when you put it back together.
  17. silk186
    silk186 Derp
    1 Dec 2014
    I've been trying to find that information... someone thinks 1mm.
  18. Anfield
    Anfield Multimodder
    15 Jan 2010
    I'd recommend a search through manuals of aftermarket coolers that are compatible to see if they mention the thickness of the original pads.
    silk186 likes this.
  19. silk186
    silk186 Derp
    1 Dec 2014
    Is it worth replacing the thermal pads? I remember graphics cards didn't even use them until recently. Would I be fine putting this back together with new thermal paste? It seems that replacing all the pads is not a cheap endeavour.
  20. Vault-Tec
    30 Aug 2015
    If you can mould the mushy things back together I wouldn't bother. They are very expensive yes.
