Displays GPU not detected
Discussion in 'Tech Support' started by silk186, 7 May 2020.
  1. silk186
    silk186 Derp
    1 Dec 2014
    I finally got around in install some Corsair ML fans along with the extra dodads for flashy rainbow lights. No lights, played around with iQue and they came on when I turned iQue off. Turned it back on and they are working. All good.
    I restart the computer to set up fan speed in the Bios. Hammer the Del key and black screen. Restart a bunch of times but no dice. Plug into the iGPU and restart. AMD software says it's buggered so into safe mode for DDU. Remove the AMD drivers and get an error when I try to reinstall them. The GPU is not even showing up in device manager and I can reinstall AMD drivers. Any idea?
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Check you have the GPU seated properly and the power cables are plugged in all the way, first thing I would check.
    souper82 and (deleted member) like this.
  3. silk186
    silk186 Derp
    1 Dec 2014
    It's worth a try. It's just odd that it happened when I tried to get into the BIOS.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I've had this a few time where reseating it fixed it.
  5. silk186
    silk186 Derp
    1 Dec 2014
    I bumped the system while moving it around and it started working again.
  6. MADPC
    MADPC Minimodder
    10 May 2020
    My experience say gpu not detected is dead.
