GPU Warranty Question.
Discussion in 'Asus UK' started by jonydg, 14 Sep 2016.
  1. jonydg
    jonydg What's a Dremel?
    18 Dec 2010
    Hi,
    Purchased a Nvidia 1080 Strix and i'm wondering what Asus' stance on warranty if fitting a GPU water block, would the warranty be voided if the stock cooler is removed?
    Thanks.
    Jony.
  2. TheMadDutchDude
    23 Aug 2013
    You will lose your warranty as there is a sticker over one of four of the screws holding the cooler in place. It's a 'warranty void if removed/tampered' sticker.
    I may be mistaken, and it may be wise to wait for someone from ASUS to confirm this ... but I have a good feeling that this is the case.
  3. Will_ASUSUK
    Will_ASUSUK What's a Dremel?
    20 Jun 2016
    Hi, If you peel the stick off to do this, which I believe you have to when attaching a water block plate, you will void your warranty. Kind Regards.
  4. jonydg
    18 Dec 2010
    There is a large sticker which isn't covering any screws but on further inspection there is a small sticker on one of the screws that holds the cooler in place.
    Should have been more patient and waited for the EVGA cards to come in stock.
    Thanks though for clearing that up for me.
    Jony
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Not that I would ever suggest doing this because it is totally underhand and stuff, but it is possible to remove those stickers intact then put them back in place afterwards.
  6. Will_ASUSUK
    20 Jun 2016
    No problem. I believe EVGA have this on their cards too as I have owned EVGA models previously.
    Kind Regards.
  7. Will_ASUSUK
    20 Jun 2016
    Tsk tsk :jawdrop:
  8. noizdaemon666
    15 Jun 2010
    Oh no yu di'n't! :p /sass
    Plus, it isn't my fault if your warranty seals are easily avoided haha
  9. Will_ASUSUK
    20 Jun 2016
    Not really an easy way to get one that works. We will know, we will know :dremel:
  10. noizdaemon666
    15 Jun 2010
    Glue. Glue everything down so if someone removes a heatsink it takes half the PCB components with it. Then sit and wait giggling like a schoolgirl for the tortured screams of thousands of PC enthusiasts.
    /Satan
  11. Vault-Tec
    30 Aug 2015
    It's absolutely that ^.
    AMD are on a very strict budget with the 4x0 cards due to them having to keep the prices really low.
    However, if you contact Sapphire (Ed in particular) they will send out review samples.
