GPUs not detected
Discussion in 'bit-tech Folding Team' started by roosauce, 21 Aug 2015.
  1. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Hi Chaps,
    This should be super quick I'm guessing.
    I've decided to get into folding. I used to do a heap of BOINC but have been out for a long time.
    I've installed the client and my CPU is cranking. The client lists 0 GPUs however, and if I try to add a GPU slot then I receive the error "On client "local" 127.0.0.1:36330: No available GPUs".
    Specs Info:
    Windows 10
    5960x
    2x 980ti's in non-default PCI-e slots if that matters
    Latest Nvidia drivers
    I tried a fresh install and deactivating SLI. Do I need to do a driver roll-back?
    I found a couple of references to this on the guru3d forum, but the solution wasn't clear.
    Thanks!
  2. roosauce
    12 Feb 2010
    Hmmm ... don't worry - sorted.
    Apparently I had to go to https://fah-web.stanford.edu/file-releases/public/ to grab the content from GPUs.txt and update my local GPUs.txt file at C:\Users\YOURUSERNAME\AppData\Roaming\FAHClient\
    I re-started the FAH client and my GPUs are now detected.
    Odd, but there you go ...
  3. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Glad you got it working.
    Appears to be a common problem with windows 10.
