News GPUStrongarm universal support hits Kickstarter
Discussion in 'Article Discussion' started by Gareth Halfacree, 9 May 2016.
  1. Gareth Halfacree
    4 Dec 2007
  2. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    whilst this should be addressed for standard tower type cases, a universal solution, would surely impose a height restriction on the card, and there's been quite a few very high cards lately.
  3. koaschten
    koaschten What's a Dremel?
    24 Mar 2011
    Is it me or is the link to the kickstarter extremely hard to find in chrome, hiding behind "live now" in the last paragraph?
  4. jb0
    jb0 Minimodder
    8 Apr 2012
    I am continually amazed that we haven't found a new standard for video adapter mounting yet that is designed to handle the weight of a large heat sink. I've been saying for years that the dang things ought to socket in like the processors do. But whatever, let's just keep dangling huge chunks of metal off an unsupported slab of circuit board that was never intended to be load-bearing. What could go wrong?
    Basically, this is a solution to a problem that shouldn't friggin' exist.
  5. Gareth Halfacree
    4 Dec 2007
    Hiding? It's bright blue or purple, depending on whether you've already visited the page or not.
  6. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Here on OS X these type of BT inline links are never very visible. There just isn't the contrast differential between the link and the text it's embedded in. I can certainly see them, they're just not as visible as on other sites.
    Sites like The Verge use red as a contrasting colour and that's on a page with a larger more airy font which also increases the clarity. The BBC goes with a heavy bold with a subtle underline - it's all about creating enough of a contrast to aid everyone - and not just those who strictly need that contrast.
    I'm sure for you there's sufficient differential between the link and the paragraph text but trust me, here on BT it's less than optimal for everyone. I'm clearly not alone in noticing your links aren't as discoverable as they could be.
    You'd never get bit-tech through a serious round of accessibility testing with an org such as The Shaw Trust. That pale blue (you call it bright blue) is a nightmare for people with certain types of dyslexia.
  7. Gareth Halfacree
    4 Dec 2007
    Which browser? Safari? I use Chrome on OS X, and it appears as per the screenshot.
    S'not my department, unfortunately: I can only stick links in things, I have no control over what the links look like once rendered. Have you thought about sending feedback in to the editor, to see if the stylesheet could be tweaked to make the links more visible - adding an underline, or using a higher-contrast colour scheme perhaps?
  8. Farsan
    Farsan What's a Dremel?
    1 May 2014
    Dyslexia? I think it is more about Colourblindness. I have it and found the link just reading normally the article, but could be great to make it more visible changing the font size, pe.
  9. azrael-
    azrael- I'm special...
    18 May 2008
    I needed to link hunt as well. The colour offset just isn't that great. I'd probably go for a different colour for links or have them subtly underlined (although that might bring back painful memories of SkimLinks). Changing the font size for something as a link is generally a bad idea, though.
  10. Guest-16
    Guest-16 Guest
    Mmm any card any case is a very ambitious claim given that
    1) there's a lot of aftermarket coolers, with some wider than standard and many vent to the edges of the card, so that could block temps.
    2) ASUS (for example) has its own support bracket built into its DCII and III coolers (Matrix is a derivative of), and its hybrid WCing block is a single plate that effectively does the same thing, so is this really required?
    3) I didn't see if it provides replacement case screws for the extra depth?
    The big advantage I can see is for aesthetic reasons with the custom engravings. But then again, if you're water cooling doesn't it defeat the point of hiding what little you can see of the block?
  11. Gareth Halfacree
    4 Dec 2007
  12. rollo
    rollo Modder
    16 May 2008
    CPU coolers weigh a lot more and have caused no damage. Not sure the point In this. I have a old frio it must be 1kg + before fans and it's been they're about 7 years still no signs of damage around on the board.
    Even on a SLI rig with water cooling on top of it I have not noticed any visible strain signs on a x58 board I recently removed.
    The removal motherboard tray is not even bent or damaged.
    These days with most motherboards offering some form of brackets themselves I think it's 3-4 years too late to the party.
