graphic card 8800GT will fit inside the coolermaster centurion 5 case?
Discussion in 'Tech Support' started by BlueOcean, 17 Apr 2008.
  1. BlueOcean
    BlueOcean What's a Dremel?
    5 Feb 2008
    I have a Coolermaster Centurion 5 case and P5K-VM, Can 8800GT or 9800GTX will fit inside the case. YES or NOT?. :confused:
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    make a cardboard piece 9 inches long... thats the length of the gt and gts. add connectors as extra length..
  3. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    Ill let you know in 3 months.
  4. BlueOcean
    5 Feb 2008
    8800GT it will fit inside the case?:worried:
  5. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    i've got a 534, not sure how different they are internally. but the 8800gt fits in that fine, just a word of warning if you have a hdd in the floppy bay then the pcie power connector and the sata connectors are pretty close to each other
  6. BlueOcean
    5 Feb 2008
    I know CoolerMaster Centurion 5 case fits inside the graphic card 8600GT, No Problems.
  7. BlueOcean
    5 Feb 2008
    I know Coolermaster Centurion 5 case fits inside the graphic card 8600GT, no problems?..:o:o
  8. Jik
    Jik A Dremel, what is it?
    19 Dec 2007
    Obvious troll is obvious.
  9. BlueOcean
    5 Feb 2008
    I'am going buy a 8800GT 512mb,
  10. gavpowell
    gavpowell What's a Dremel?
    18 Apr 2008
    It depends how you have everything set up as to whether it will fit- one of the main problems you could ave is if your motherboard is poorly designed, the card could be too wide/long and interfere with other hardware, block PCI slots etc. Your other issue is the cards are quite high, so you could find they'll run into any hard drives you have positioned in the way - might need to move drives around inside the case etc.
    Go for it either way though, you can always send it back if it doesn't fit.
