Grr, how to chmod a directory for full access
Discussion in 'Tech Support' started by ahug4122, 20 Apr 2008.
  1. ahug4122
    ahug4122 What's a Dremel?
    16 Sep 2004
    I have searched and searched google how to CHMOD it and can only find out how to do files not directories.
    I have directory on my desktop called "Ashley BACK UP" its has alot of my work on it now i only have read only access and its all in subfolders and there is about 3k file and folders on it. How do i chmod it so that i can have full access to all the files and folders? I can do it for all the files in a directory but not the subfolders and sub files
    Tnx in advance Ash
  2. ahug4122
    16 Sep 2004
    BTW MacBook (running Mac OS 10.4.11)
  3. Glider
    Glider /dev/null
    2 Aug 2005
    Probably the same on Mac, but on Linux it's
    Code:
    chmod -R 777 /path/to/directory
    Note of warning, 777 is a very open and insecure mode...
  4. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    Yeah, open a terminal and do what Glider says. But there's no root account on OS X so you'll have to use
    Code:
    sudo chmod -R 777 /path/to/directory
    otherwise you'll get some permissions errors I'd imagine.
  5. OleJ
    OleJ Me!
    1 Jul 2007
    -R means recursive. In case you don't want to set subfolders to 777 then remove the -R
  6. trigger
    trigger Procrastinator
    22 Mar 2004
    Incidentally (and purely out of curiosity) does anyone know whether Mac OSX has man pages?
  7. ahug4122
    16 Sep 2004
    I have tried what you say and this is what i get
    Code:
    cpe-121-210-147-225:/ myerparramatta$ sudo chmod -r 777 /Users/myerparramatta/Desktop/Ashley\ BACK\ UP/
    Password:
    chmod: 777: No such file or directory
    But the directory is there and now when i try and open it, it says i have no access i look at the get info panel and it says write only so i have to can it manualy thru the get info panel. All the subfiles and subfolders still read only
    Anything else i can try
  8. Glider
    Glider /dev/null
    2 Aug 2005
    Capital R instead of r ;)
  9. Firehed
    15 Feb 2004
    Sure, it's the full BSD shell underneath.
    Of course, you can do this in the GUI too. Cmd+I on the folder to get info, click the little lock icon in the bottom-right to get editing access, and then set things appropriately in the permissions bit at the bottom.
  10. ahug4122
    16 Sep 2004
    THANK YOU
    Fixing that letter case do it YAY
