Windows gta II
Discussion in 'Gaming' started by ry@n, 1 Sep 2005.
  1. ry@n
    ry@n Minimodder
    31 Aug 2005
  2. dom_
    dom_ --->
    4 Jan 2004
    click on the setup icon (twice)
  3. ry@n
    ry@n Minimodder
    31 Aug 2005
    tried that and it says: the system file is not suitable for running MS-DOS and microsoft windows applications. what now?
  4. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I'm not if sure if you can with setup files, but try right clicking, properties and go to compatibility and change it to windows 95, or 98
  5. furqan
    furqan What's a Dremel?
    2 May 2004
    yeah you should be able to change the compatibility to windows 95 or 98 on the setup file
    (Why did you get gta2, the original gta is sooo much better :) )
  6. ry@n
    ry@n Minimodder
    31 Aug 2005
    ive tried that but it still wont work, any other ways?
  7. keir
    keir S p i t F i r e
    5 Oct 2003
    downloading it now, just to see :rolleyes:
  8. keir
    5 Oct 2003
    you sure you downloaded it from rockstar, I open'd the .zip file and there was only 2 files. a read me.txt and a GTA2.exe wich was the installer.
  9. CrOaKeR
    CrOaKeR Host warrior 4, Vengence!
    21 Feb 2002
    I have seen the error "the system file is not suitable for running MS-DOS and microsoft windows applications" when the autoexec file has been damaged due to spyware/virus. I speak to users that get it everyday.
    Try anti spyware scan, like spybot. Then retry.
    Hope it helps :D
