Graphics GTX460 high pitch noise!
Discussion in 'Hardware' started by pyro1son, 3 Jun 2011.
  1. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    When my GTX460 is under a full load it seems to make i high pitch noise!
    Is this normal?
    What do i do to stop it?
    Thanks guys!
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Sounds like coil whine. My 5770 has it, as yet I don't know of a way to stop short of getting rid of the card.
    It is normal, if annoying I believe. I think it's the capacitors which make the noise though not sure.
  3. Tangster
    23 May 2009
    Get a new card. That's it really, next time buy a card with higher quality components, ie, all solid caps.
  4. pyro1son
    18 Aug 2010
    It's not even a year old!
  5. Randomeclipse
    Randomeclipse Minimodder
    11 Jan 2011
    Able to get a replacement under warrenty perhaps?
  6. pyro1son
    18 Aug 2010
    I shall try! Do they replace for that problem?
  7. Tangster
    23 May 2009
    I don't think most companies do replacements for problems that don't affect the performance of the product. Worth looking into though.
    If not, I've heard that covering the coils with hot glue can often correct the problem.
  8. bulldogjeff
    2 Mar 2010
    They have to, although not impacting on performance it's still a defect. It;s not meant to whine, simple as that.
    If only it was that easy to send women back when they start whining......
  9. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    Idk, I have to say most companies will probably treat the card as non-defective if it just whines but otherwise works fine, they'll blame the rest of your system i.e. PSU, whatever. Except maybe XFX--they will not only send you a new card, but also a box of chocolates and a discount on a local stripper. Yeah they're THAT good lol.
