I've been looking at replacing my ageing GTX 560ti for a GTX 970, and have noticed that it uses a single DVI-I and DVI-D connection (y u do dis?!) . I have two monitors at the moment that are both connected via DVI-I, so could I get away with the using the DVI-I and a HDMI cable to power both monitors? I don't particular want to have to buy a new cable just to use the D (fnar fnar)...
Yep, you can use any combination of ports up to 3 displays but check if your cables have the 4 pins around the large flat horizontal pin. If they don't (like this), then the two DVI ports will work fine
Good news, both of my cables only have the single flat pin and not the extra four that surround it. I was thinking of going with MSI again too because the current one is an MSI, and that's been pretty good to me so far.
