Reviews Halo 2 Anniversary PC Review
Discussion in 'Article Discussion' started by bit-tech, 28 May 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    I feel bad for Saber Interactive whenever someone points out the flaws in Halo CE, because they didn't get the Xbox version of Combat Evolved to work with, they got Gearbox's PC port, which is infamous for it it's lack of polish. I dread to think what it's like trying to re-master a port that downgraded or broke a bunch of the graphical effects, it also makes think the original CE source code must be lost to time somehow.
  3. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Given that FF VIII source code was lost (Which, IMO, adds credence to the theory that, perhaps, studios don't always back **** up and archive it either properly or at all), I'd definitely bet that the Halo CE source has gone the way of the dodo.
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I'm less sympathetic as many of the issues have proved fixable (as with modded versions of PC CE) but remain unfixed for anniversary.
  5. Paradigm Shifter
    10 May 2006
    This really reminds me I need to install this again and actually make a proper attempt to play it.
Tags: Add Tags
