it's time to insert the panels and see the effect it has with the motherboard mounted... for this mod I chose the new EKWB velocity 2 CPU water block which has a bigger tray and is really nice to look at next step study of liquid system positioning radiator and taca with integrated pump
here we go guys installing leds on house panels.. the case, as you have already seen, is particular, it has the motherboard rotated by 90° and I found a solution for installing the tank radiator with the special EKWB support, the tank is effectively positioned on the 360mm radiator by fixing it above the fans. to stay on the theme, paint part of the fittings to further resume the halo world theme, the EKWb personalized rings are additional rings available in various colors.. to test the finished system, use this tool which allows you to understand if there is a leak and intervene before introducing liquid for now insert neutral liquid i will buy it later. other led lights these are branded sharkoon as well as being adhesive they are magnetic!! cablemod cables. first start. to color the liquid I use rgb ekwb allows you to create customized colors according to your needs.. inno3d ichill rtx 3070 video card already seen at the beginning of the worklog https://www.inno3d.com/en/product_detai ... ed9e47392a processing of the side panel in tempered glass latest graphics application internally applied vinyl Halo finished first shots, soon better photos of course
Hi Guys, the project is finally finished first shots.. a big thank you to all the sponsors who joined this project, Asrock, Ekwateblocks, Cablemod, hwlegend, inno3d, patriot vipergaming, and of course sharkoon
Looks superb, great work! Did you run into any problems with the military green paint getting damaged when tightening the compression fittings?
