Graphics Hard to choose ONE!
Discussion in 'Hardware' started by ComputerKing, 14 Nov 2006.
  1. ComputerKing
    8 Sep 2006
    Guys I'm Going TO build A very Strong System But im Very Disspoint in Vga Cards
    Guys I was Crazy and I was going TO die :D Which one I can get !!!!!!!
    Ok here
    1- 8800GTX With water block BFG 800$
    2- 2 X 7950Gt In Sli With Thremeltake WaterCooling System For them 650 $
    3- X1950XTX One Of it with a DangerDen Water Block I think round 650 $ too
    4- 2 X x1950pro Crosee Fire Like Sli !!!!
    Or Which Card !!!!
    i have 800 $ to spent on Vga CARDS ( WITH THE WaTERBLOCK or With SPicaly SYSTEM )
    I WILL GET THE evga nforce 680i MOther Board and e6600 :D 1066 2gb ram !
    This the Water Cooling For VGA's what i was mean
    http://www.crazypc.com/products/93600.html
    its Thermaltake Tide Water Plus DUAL VGA Water Cooler CL-W0086
    So help me Out of this !!!! plzzzzzzz :wallbash: :wallbash: :wallbash:
    I'm going to buy Them on 2 days more
    I want Quilqly help and Sugg...
    Sorry for Bad English
  2. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    The 8800GTX is faster than anything else there
    Approx order of speed, fastest to slowest:
    1. 8800GTX
    2. 2x7950gt in SLI
    3. 2x x1950pro CF
    4. x1950xtx
    The 8800gtx surpasses all the others on image quality as well as speed. Its CPU limited so it'll be good for several upgrades and its dx10 compatible so it is designed for future games.
    If you play on 1650x1080, 1600x1200 or above resolution monitor then any option will be good. If you play on a 19" or less monitor then these cards are overkill and a single 7900GS or x1950pro will be fine for max detail, AA/AF.
  3. ComputerKing
    8 Sep 2006
    ok I want To Run Need For Speed CArbon At the Maxuimum And I need it smothly and spedly :D and also the Bf2142 :D
    So IF I go With 8800GTX With Water Block ::: THIS ONE ::: Those 800$
    http://www.bfgtech.com/8800GTX_768_PCIe_wc.html
    Better Than
    2 X EVGA 7950GT With This Cooling ::::::::::Those 650 $ ::::
    I want TO PLAY HARD AT THE MAUIMAM AND WITH BEST TEMPS AND KICK ASS Also I want To Work In Wideo Editing :D
    I have 17 " Wide Screen I think Its was Run at 1280X1024 I think or soem thing else :D
    SO Give me The Final Word :D
    This the PC spec
    eVGA Socket T (LGA 775) NVIDIA nForce 680i SLI ATX Intel Motherboard
    Intel Core 2 Duo E6600 Conroe 2.4GHz 4M sharing L2 Cache LGA 775 Processor
    CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
    GeForce 8800GTX 768MB GDDR3 PCI Express x16 HDCP Video Card Water Cooled - 1/2" fittings for 1/2" inner diameter tubing BFG Tech
    GALAXY ATX/BTX 1000W Power Supply 100 - 240 V ENERMAX
    SOUND BLASTER X-Fi Fatal1ty FPS 7.1 Channels 24-bit 96KHz PCI Interface Sound Card Creative
    Caviar SE 80GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive Western Digital
    2 X Caviar RE 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive Western Digital
    Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE Super-Multi DVD Burner LG
    120mm Blue LED Light 3D Galaxy II Liquid Cooling GigaByte
    Volcano 405 Heat Exchanger CPU Water Block for Liquid Cooling Systems Thermaltake
    G15 2-Tone 104 Normal Keys USB Wired Standard Keyboard Logitech
    931376-0403 2-Tone 6 Buttons 1x Wheel USB Laser Mouse Logitech
    Man Are you fell Me I want Play Games Like Hell MAxuiumam
    I Dont think that I will Work with 1600 X .... lol
  4. ComputerKing
    8 Sep 2006
    ok you said ''''''''''' then these cards are overkill ''''''''''''''''
    thats what I need on 19" screen New One :D Wide Screen
    And With My New 2 Games 1- bf2142 2- N4S CarBon :D
    YEAH BABY I WANT SEE THIS 8800GTX GO TO THE MOON I WANT SEE TEH ROCKS MONSTERS :D
    So you Are sure , Mean I go Head And Get 8800Gtx ( ONE ONLY ) :D
    and Mod My BigASS CASE AND Post here :D
  5. Awoken
    3 Mar 2004
    If its a 17" widescreen then a single 7950gt will give you full settings at excellent speeds. If you're going for a 8800GTX you won't see any benefit over a 7950GT even on a 19" widescreen.
    At 20" you'll start to see a slight benefit, it'll run full settings in the newest games smoothly but so will 2x7950gt in SLI or a x1950xtx.
    At 24" the 8800GTX will be a worthwhile card and nothing else will touch it.
    So get the card to suit your monitor. For reference:
    A 19" widescreen LCD costs ~£200-220
    A 20" widescreen LCD costs ~£260-280
    A 24" widescreen LCD costs ~£580-620
  6. ComputerKing
    8 Sep 2006
    yeah right now its 17" widescreen I Want MAXUIMUN settings at OVERKILL SPEED
    And I want TO Work With Adobe Preimire And AfterEffect !
    And IMportant Thing The Games I want Them Work Liek Dreams And Like My real Eye Drive Car So What you say !!
    If they 7950GT Sli I think the Core Speeds Will BE : 1150mhz ...
    Memorey Speed will BE : 2900mhz ..
    So MAN I WANT OVER KILL IN 17" Wide Screen And For Future 19 " wide Too !!!
    So I want A good Decdied !!!! !
  7. Awoken
    3 Mar 2004
    A single x1950xtx is all you need if you plan to go for 19" widescreen, just get the cheapest one you can and overclock it. Even that will be overkill.
    For image/video editing the CPU is far more important than the gfx card as it does all the work. A pentium core2duo will be best, try the 6300 or 6400 and get some good PC6400 DDR2 to overclock it with.
  8. ComputerKing
    8 Sep 2006
    Ok see This
    Mobo : Evga nForce 680i SLi
    Cpu : intel Core 2 Duo E6600
    Ram : CORSAIR Dominator 2GB 1066 (PC2 8500) Dual Channel Kit
    PSU : ENERMAX GALAXY ATX/BTX 1000W Power Supply
    Sound : Creative SOUND BLASTER X-Fi Fatal1ty FPS
    Vga : 7950Gt X 2 Sli
    or x1950xtx
    With Full Water Cooling For Cpu and Vga To OC Them to the MAX I will OVERKILL THEM IN OC DNT WORRY
    But I WANT TO PLAY GAMES LIKE WHAT I SAY ,,,, EXTREMELY ..... I DONT KNOW HOW TO SAY IT BUT I FEEL IT !!!
    19 " wide and 17 " wide For Now SO What you Advise Me
    I want A firend Advise :D
    HARD GAMING :D
  9. ComputerKing
    8 Sep 2006
    How Ever !!
    I Was Making Price List !! I Saw that There are 100 $ Diffrent Bettwen Get
    1- One 8800 GTX With The Water Block BFG ! 800 $
    2- Two X 7950Gt Sli With Spicaly Water Cooling system ! 700 $
    SO This Make Me Fkin Crazy !!!
    If I get The ( 2 ) I will Have Dx9 And 2 water Cooling System In MY PC And ( 1GB VGa )
    If I get The ( 1 ) I will Have Dx10 And 1 Water Cooling System In My Pc And ( 764 mb Vga Or some Thing )
    !!!!! SO what I DO !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I WANT THE BETTER PREFOMANCE FOR NEXT LIFE AND GAMING !!!
    CAN ANY ONE TELL ME !!!!! PLEASE HELP ME OUT !!!!!
    MY BRAIN WILLL BURN BECASUE OF THIS !!
    Edit : !!!! WTF WITH 8800GTS !!!!! THIS MAKE ME CRAZY !!!!!!!!!!!!!!!!!!!!
    SO ANY SUG .. Or Advise OR ANY THING !!!! THANKS
  10. bllt2bnry
    bllt2bnry What's a Dremel?
    2 Oct 2006
    Do you have ADHD?
    On topic: I don't see the point in getting an amazing graphics card if you're using a 17'' monitor. Save the extra money you would spent and get some decent games.
  11. Krikkit
    21 Jan 2003
    Well said. :hehe: Can't see the need for caps and exclamation marks myself.
  12. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    i think my brain melted.
  13. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    if you definetely want to buy a dual card system go right ahead. you'll be able to max out any game you care to mention. you'll have wasted your money horribly but theres always worse things to buy
  14. Dustin
    Dustin What's a Dremel?
    22 Apr 2006
    rofl @ this highly leet masterpiece
    I would suggest you getting a 7950GT if you dont plan getting over 20"
  15. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    If you really care about DX10 peformance, and not having to upgrade when games actually come out for DX10 that you want to play, then the 8800 would be a better choice. If you don't care about DX10 games for a while, and don't mind upgrading then, go with the 7950s
  16. ComputerKing
    8 Sep 2006
    yeah
    I dont have ADHD :D !!! ADHD what this mean :D
    I have The DVI 17" WIDE Screen !
    And I'm Upgradin To play Games on max and Very Smotly and KICKASS
    I Want To smook The Games You fell me it's liek a BMW or Mesrcdes Car :D
    And I Dont Care For now about dx10 I want Play :
    1- Need for Speed CarBon
    2- BattleField 2142
    On the MAXUIMNM :D MAX AND SPEEDLY :D :D:D
    AND When DX10 Games out I will Upgrade My Same System TO 2 X 8800GTXS or Some Thing Will Be out In More 6 Mouths or So !!
    SO I THINK THE BEST CHOISE LIEK YOU SAID GUYS
    THE 2 X 7950GT EVGA :D WATERCOOLED :D
    I WANT TO OVer Clock Them To the max :D
    I WANT OVER KILL PC lol :D
    So What YOu say Guys !! GO ahead with 7950Gts and save extra money for moding :D
    I Will wait the LAst Advises For you Guys TOday last !!!
  17. ComputerKing
    8 Sep 2006
    OK here What I Just Choisce For My Gaiming Computer :D
    1- eVGA Socket T (LGA 775) NVIDIA nForce 680i SLI ATX Intel Motherboard
    2-Intel Core 2 Duo E6600 Conroe 2.4GHz 4M sharing L2 Cache LGA 775 Processor
    3- CORSAIR Dominator 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
    4- eVGA GeForce 7950GT 512MB 256-bit GDDR3 PCI Express x16 KO Superclocked Video Card
    5- eVGA GeForce 7950GT 512MB 256-bit GDDR3 PCI Express x16 KO Superclocked Video Card
    6- ENERMAX GALAXY ATX/BTX 1000W Power Supply 100 - 240 V
    7- Creative SOUND BLASTER X-Fi Fatal1ty FPS 7.1 Channels 24-bit 96KHz PCI Interface Sound Card
    8- Western Digital Caviar SE 80GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive
    9- Western Digital Caviar RE 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
    10- Western Digital Caviar RE 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
    11- LG Black 18X DVD+R 8X DVD+RW 8X DVD+R DL 18X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE Super-Multi DVD Burner
    12- Logitech G15 2-Tone 104 Normal Keys USB Wired Standard Keyboard
    13- Logitech 931376-0403 2-Tone 6 Buttons 1x Wheel USB Laser Mouse
    And Water Coolign Cooling Thinking Soon
    Guys I just Saw This Screen Its 19" wide Screen !!! I WILL GET IT !!
    http://www.newegg.com/Product/Product.asp?Item=N82E16824116373
    Does It Work Rocks And OVERKILL AND KICKASS AND SMOOK WITH THE 2X7950GT !!!!
    Mean I THINK I WILL RUN 1440 x 900 !!!!!!!!! SO I WANT ROCK WHAT YOU SAY !!!
  18. M4RTIN
    11 Sep 2006
    have you actually istened to what anyone has said.. or does it need to be written in capitals with very poor grammar
  19. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    All that hardware and you're only getting a 19 incher :eek:
  20. M4RTIN
    11 Sep 2006
    its how you use it that matters... well thats what i always say :duh:
