Other Hardware for mobile vloging?
Discussion in 'General' started by silk186, 20 Mar 2020.
  1. silk186
    silk186 Derp
    1 Dec 2014
    This is a bit of a niche area but I'm hoping someone can offer some advice. My wife, to pass the time, has started a Douyin account, the Chinese counterpart to TIkTok. She records and edits video on her Huawei P30 Pro, which like many new smartphones, lacks a 3.5mm jack. This really limits hardware options.
    I'm looking for a microphone that will connect to her USB-C port, has a gains control and will offer better audio quality and isolation without overly increasing the complexity of recording.
    I ordered a Logitech Blue Microphones Yeti USB Microphone and USB mini to Type-C cable. Does anyone have experience with this type of setup? I'm looking for advice and recommendations. Does she need to use OpenCamera?
    I was thinking about a miniboom mic:
    • BOYA BY-DM100 Digital Stereo Cardioid Condenser
    • Saramonic SmartMic+ UC
    • Comica CVM-VS09TC
    After more research, I know that BOYA pushes turds that are rarely function correctly. I was hoping for a more portable solution for outdoor recording.
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  3. silk186
    silk186 Derp
    1 Dec 2014
    I picked up the Yeti Blue for £65 used.
    A Rode Wireless Go is £145 (£85 used) + Deity V-Mic D3 Pro £158 = £300
    I will hold off on spending that much until I see how far she goes.
    A dji osmo mobile 3 would also be nice eventually.
  4. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    I'm afraid I can't really comment on hardware, since all the recording I've done with digital interfaces has been on a PC using full-sized USB ports...
    I did however use Voice Record Pro on my iPhone quite a lot when I was recording motorcycle vlogs a few years ago. There is an Android version available, but I've never used it; thankfully the Android version seems to be free, whereas I had to pay for it on iPhone. I used to use it with an Audio-Technica ATR-3350 lapel mic (which won't help you, since the ATR-3350 has an analogue 3.5mm plug)
    silk186 likes this.
  5. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    IIRC, Android has native support for USB audio, i.e. your standard desktop USB DAC/ADC/mic should be plug and play with a simple Type-C to USB A adapter. If super-compactness is not an issue, you can potentially use a Type-C to USB A adapter, a USB hub, then plug in whatever USB mics you want. If you want ultra potableness, then a Bluetooth lav mic may be the way to go.
    silk186 likes this.
  6. Byron C
    12 Apr 2002
    That might not be a bad idea, as long as battery life isn't going to be an issue.
