CPU Haswell Overclocking
Discussion in 'Hardware' started by GeorgeK, 8 Sep 2013.
  1. GeorgeK
    18 Sep 2010
    Afternoon all
    Just wondered who else on here has had a bash at overclocking a Haswell chip? Mainly wondering what volts you're using and what frequency you're getting with that? Just starting having a fiddle around with my setup and I seem to have got 4.3GHz stable using 1.15 volts. Getting temps of around 66°c using a H100i and quiet fans.
    Over to you!
    Cheers
    George
  2. teppic
    teppic What's a Dremel?
    18 Jul 2011
    It varies a massive amount. My first 4770K needed 1.3v just to get 3.9GHz stable, so I returned that to Amazon. The second needed 1.3v for around 4.4GHz.
    I've got a second system with a 4670K, and that needs 1.3v for 4.6GHz.
    Overall it seems that up to 4.2GHz is normally ok around 1.25v or lower, while some chips can't feasibly do over 4.3GHz and others can get to 4.8GHz.
  3. GeorgeK
    18 Sep 2010
    Looks like I spoke too soon with mine - I'll try upping the volts a little to see if that helps
  4. teppic
    18 Jul 2011
    Did you crash?
    Some people have chips that can get 4.7GHz stable at 1.19v, others can't get to 4.3GHz at 1.35v. It's a terrible chip for overclocking compared to SB/IB - it's too unpredictable.
  5. GeorgeK
    18 Sep 2010
    Yeah - bloody typical! It survived about 2½ hours of prime at 4.3GHz with 1.17v but then crashed again so nearly stable but not quite yet. I'll dial it back to 4.2GHz for now and have a bit of a game and then continue fiddling with it later I think.
  6. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    I heard direct from 8Pack that with Haswell he binned huge amounts of chips to get good ones. The silicon lottery is quite poo.
    I am tempted to pick up a binned chip. As I have a contact but they are fussy about selling them :lol:
  7. TheMadDutchDude
    23 Aug 2013
    My 4770K needs 1.3v for 4.5GHz and hits 90c under a SB-E Extreme cooler, under Prime95 without AVX. With AVX, it throttles almost instantly. It's ridiculous.
    andrew8200m likes this.
  8. teppic
    18 Jul 2011
    I've given up with Prime95 testing. I try the Intel tuning tool stress test for 5 mins, and then play a few games - no crashes and I'll keep it. Since Haswell gets so hot so quickly on artificial stress tests I don't think it's very suited to them.
  9. djzic
    djzic Bokehlicious!
    8 Nov 2010
    I'm at 4.3 on stock volts - I can't go any higher voltage because of the cooler I'm currently using (bear in mind I don't want noise :)) so once I get a cooler that's a little more performant I think I'll be able to crank this thing high :D
    However I haven't actually tried pushing higher - I might when I get some time :)
  10. GeorgeK
    18 Sep 2010
    I was watching this
    and reading this and it effectively says that something like Prime95 runs the processor harder than any normal application, to the point where you shouldn't use their Adaptive Mode for the voltage as when the processor notices you're running something with AVX instructions it'll ramp up the voltage by ~0.1v
    Interesting, if confusing in places, reading!
  11. TheMadDutchDude
    23 Aug 2013
    That's why you use manual voltages. ;)
  12. GeorgeK
    18 Sep 2010
    My thoughts exactly - it's an interesting concept but I'd always be paranoid that it was going to ramp up the voltages without me noticing. I suppose if it was only to ever do it when you were running programs using AVX instructions then that'd be fine but I'd worry it was doing it other times too!
  13. rollo
    rollo Modder
    16 May 2008
    The days when prime is a go to for stress testing ended with ivy really.
    Best thing is to do what you normally use a pc for. Most users will never max the CPU the way prime does so its not a very relivent test.
    If all you do is game most games won't even show a 30-40% load on a modern intel CPU.
    I run a quick intel burn test make sure temps don't hit 100c instantly then play a few games check temp if its sub 80c then I'm pretty happy. Don't overclock my other rig as stability is more critical.
  14. teppic
    18 Jul 2011
    I'd prefer a high load realistic test. For example, I use Linux as well and so a full kernel compilation using all cores is quite a good test. Another one would be a handbrake encode of a DVD or something.
    Varied testing is important though. I've found that I can be 100% stable in Prime for 30 mins, and yet still crash in a game a few minutes in. That's why I prefer a varied amount of shorter realistic tests.
  15. GeorgeK
    18 Sep 2010
    That's why I like & repect the CPC benchmark suite actually as it's doing stuff we do regularly (other than gaming)
  16. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    No no no PRIME is a great stress test because its above and beyond what you normally do and as such leave a amount of security in you OC. Better yet use F@H and boost the teams rating while you burn in. OC should be rock solid or just bench testing everything els it PFFF! ;P
  17. teppic
    18 Jul 2011
    Gaming is an excellent test though, the more CPU intensive ones tend to go up and down very quickly in CPU usage a lot, which is important to test in addition to flat out 100% usage.
  18. GeorgeK
    18 Sep 2010
    Fair point. The thing I always wonder is why an overclock will fail after 3 hours if it's stable after half an hour - it can't be a temperature thing as the temperature has stabilised after 20 or 30 minutes, so what causes it to happen...
  19. teppic
    18 Jul 2011
    Varying calculations, it's not the same test over and over again.
    I think that Prime95 is an excellent test for systems that need 100% guaranteed stability running applications that will stress the machine, or for testing the stability of a CPU at stock clocks. For gaming and general use it's excessive, as it'll push the CPU harder than you'll ever experience in normal apps.
  20. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    when I OC'd my C2D I ran Prime, F@H and had it set up with down clocking when not needed back in the FSB OC days :). then I lost the settings and just let my P5K Delux auto OC, which it did like a champ. THe one time it died was when there was a Giant dust monster in my cooler. But I defeated it with an air compressor and a vacuum cleaner. That must have been a sight to see!
