I need to know how effective my water cooling system is before i make a block and putt it in my computer. Is there som formula to calkulate this and i need a heat sorce to heat upp the water any ides?
going by your sig, it won't matter a huge amount. You could probably run it off an 80mm rad with a fairly quiet fan. ./spellcheck *Don't get pedantic now. I've seen English language posters do a lot worse. --Nexxo well, you have a non-natively-english excuse I suppose
You should probably mention what kind of tools your planing on using to make this waterblock. And youll never know exactly how well it will work until its tested.
There is a guy at The Mod Fathers called Titch who has a CPU made from brass that can simulate any heat output so can test pretty much any block quite......well very accurately but that kind of testing takes time which inevitably costs money. If you want temps to the enth degree........he's your man!
Sory for the spelling im from finland. AND read my signature. I need to explain this sory for being unclear. I Don't have a Block so i need some thing that generates heat just to test the rad. I have a home made rig the rad. is from moped don't remeber what "brand" it is. Zusuki AX or some thing lika that, a AX at least. Need to test the radiator. Dam my spelling sucks.
Your spelling is a lot better than that of some of the native English speakers on these forums. Don't sweat it.
