Storage HDD Data corruption following accidental unplug
Discussion in 'Tech Support' started by TheStockBroker, 26 Nov 2009.
  1. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    A now sordid evening in the Broker household.
    I made the mistake of unplugging an external SATA hard drive (USB not ESATA) while it was powered on and connected to my computer. I quickly rectified my mistake, however, now - while the disc shows all the files previously on the drive; it fails to load any of them; with each corresponding application giving an appropriate error.
    I'm confused and annoyed as to how this happened, considering no files on the drive were opened, or being accessed - the drive was just idling & given the speed with which I reconnected the power, surely not every of my 320Gb of files could be affected? [which they are].
    As the drive is an external one, Win 7 won't allow the checking for the disc for errors.
    I thought that perhaps it was something wrong with the filesystem (in line with my comment about how every single file was affected) - how would I go about confirming this, and indeed solving my little dilemma, a lot of the files are irreplaceable!
    My regards, and thanks in advance.
    TSB
  2. droitwichdosser
    droitwichdosser What's a Dremel?
    25 Apr 2009
    just going to throw some ideas in (probably wont be of any use, but hey, i tried)
    can you copy them from the external drive onto your main drive and try opening there?
    can you access them through a dos prompt?
    what about removing the drive from the casing and plugging it inside the PC?
    sorry not much help :(
  3. saspro
    saspro IT monkey
    23 Apr 2009
    How irreplaceable are they?
    This has the signs of a very expensive recovery.
    Turn the drive off (safely) and don't turn it back on until you answered my question (and had a response)
  4. DMAthlon
    DMAthlon What's a Dremel?
    7 May 2006
    run cmd.
    CD to the highest level of the external drive (ie E:\ or F:\)
    enter in "chkdsk /f" (no quotes) and it MIGHT ask you to reboot to perform this action. It will for sure if you try chkdsk /f on the OS partition.
    anyway, yeah, try that. It may take a while for it to go through but I think this may work.
