HDD Enclosure: eSATA works, USB does not. erwtf
Discussion in 'Tech Support' started by OtakuHawk, 20 Mar 2008.
  1. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    hey folks. I scraped a bit of cash, and bought a 1 TB HDD to put into a mobile enclosure to sneaker net things around in.
    I plugged in via eSATA, and formatted NTFS. everything worked great.
    however, not every place I go has eSATA, so I'd like to get the USB interface working. the USB interface appears to be completely dead. no response on any computer, *Nix or windows, no matter which order I do things (Plug in, power on/power on, plug in, etc).
    both windows boxes are XP SP2, so LBA shouldn't be a problem, not that it matters, as the drive doesn't even show up in storage manager.
  2. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Assuming you've tried a different USB 2.0 cable, it does indeed sound as if the USB 2.0 port on the enclosure is borked :rolleyes:
  3. OtakuHawk
    30 Apr 2003
    success!
    it was indeed the USB cable.
  4. Hazardous
    21 Jan 2004
    It's often the simplest/quickest solution which escapes us :D
