Storage HDD formating
Discussion in 'Tech Support' started by Publ!c Enemy, 29 Nov 2010.
  1. Publ!c Enemy
    Publ!c Enemy or Richard for short
    4 Jul 2010
    Hello, i have recently bought an SSD, which is now the boot drive, and have finally found another SATA cable to plug back in my older 1TB HDD. I have got all the apps and games saves and everything else off it now.
    My question is how should i format the 1TB drive, so it can be a media drive? Go into windows and right click, format HDD, or use the windows 7 installation disk.
    One other thing is what unit allocation size should i use 4096K?
    Thanks, Richard:)
  2. adam_bagpuss
    24 Apr 2009
    just right click and format using the quick option and leave everything as default no need to change anything.
  3. Publ!c Enemy
    4 Jul 2010
    Thaank you, sorry i didn't say it earlier.
    all worked fine:)
