Well, I was trying to re-format my RAID 0 setup with 2 WD200gig SATA hdd's. Now when I was trying to setup the RAID array, I got the one to be recognized as a normal 200gig hdd, but the other is showing the serial code of a 250gig hdd and is displaying 0 space. Is it a done drive? Or is there something else it could be.
Your RAID setup cannot be set up correctly the 2 Drives should show up as only 1. IF you are trying to stop it being RAID then if the BIOS is reporting correctly the partitition table is most likely borked. FDISK will fix it.
Umm... I'm trying to recreate the RAID array. I already deleted the old one. I'm saying that one of the hdd's isn't being correctly displayed.
