Apple Headphone problem in Powerbook
Discussion in 'Software' started by Ligoman17, 5 Aug 2005.
  1. Ligoman17
    Ligoman17 What's a Dremel?
    10 Dec 2003
    Hi,
    I have a 12" powerbook and an iPod shuffle. I am using the earbud style headphones that came with the iPod shuffle to listen to music on my Powerbook. The problem I'm having is that sound is only coming out of the right earbud. When I unplug the headphones from the powerbook and try them in the iPod, they work fine. Any idea what might be going on?
  2. RTT
    RTT #parp
    12 Mar 2001
    Checked that balance is centered? :D
  3. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Are you sure they're all the way in (snigger). They have to be all the way into the socket to fully connect.
  4. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Try what RTT suggested (and check other settings are correct too) or it might be possible that the headphone port on the powerbook is busted.
    edit:
    That's a good point too. Make sure they're going in all the way and try different headphones on the powerbook just to make sure.
  5. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Had the exact same problem. And just as RTT suggested, my balance wasn't centered. I hadn't changed it myself, but everything was "fixed" after centering it.
    System preps >> Audio > Out > Balance
    Should fix the problem.
    Good luck
    L
  6. Ligoman17
    10 Dec 2003
    Great, I'll try that when I get home
  7. Ligoman17
    10 Dec 2003
    Ok I checked the audio properties and sure enough the balance slider was moved all the way to the right. Strage considering I am sure I've never messed with the sound properties...
    Anyway, thanks RTT! :clap:
  8. Glad you got ure problem fixed mate! :)
